Alternative to Assos active wear cleanser
Roel W
by Roel W
A typical example of expensive unneccessary after-market stuff.
"I've spend so much mony on my ... that expensive accessory is actually not that expensive compared to the product."
Applicable on smartphone cases, Assos cleanser,....
Just use regular detergent fork dark colors. Much cheaper and works perfect. Rinse with vinager (avoid fabric softener on sports clothing) to keep colors fixed and to remove bad odors.
CANYON Ultimate AL 2010
CANYON Ultimate CF SL 2014
CANYON Ultimate CF SL disc 2018
Instagram @roeleur
kode54
by kode54
I never used the Assos wash...but always hang dry regardless of what detergent I use. I think the dry cycle is more of a concern than the wash cycle.
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Chebacco + DA9170 + Enve G23 CK CL hubs
- Allied Able + DA9170 + Enve G27 CK CL hubs
RTW
by RTW
Never use the dry cycle on sports clothing.
ico
by ico
Roel W wrote:
Wed Feb 20, 2019 11:52 am
That's what I used to do and my S7 bib shorts are partially transparent now :lol: There must be some component in Assos's textiles that interact with certain detergents and weakens its structure.
RTW
by RTW
Normally it is sweat that weakens the structure. Anything you have worn which is likely to have been sewer soaked should be washed immediately - like you would wash salt water out of a wetsuit.
*sewer should say sweat, but I will leave the autocorrect in, because it’s funny.
onemanpeloton
by onemanpeloton
I didn't even realise that sports detergent was a thing!
What makes this stuff unique? Is it more antibacterial/anti smell compared to normal detergent or is it more gentle on the fabrics?
2017 Giant TCR Disc
2015 Giant TCX
2016 Cube Stereo 140
nickf
by nickf
Tide Sport works extremely well for me.
ico
by ico
If it is sweat which weakens sport specific textile (particularly used in S7 bib shorts), then it would be weird. because it should be intended for such a use. I don't want to overthink this, but it definitely is an issue. I always wash them immediately after the ride.
TonyM
by TonyM
Some detergent are quite agressive.
I only use very mild detergent.
BdaGhisallo
by BdaGhisallo
What about Win detergent? Anyone tried it?
https://www.windetergent.com/
petromyzon
by petromyzon
Sweat and road grit are bad for your bibs. So is washing them. I use a mild regular detergent and a mesh wash bag and I absolutely avoid fabric softener which deliberately degrades fibres to give a softer feel.
Other than that I just ride and enjoy. Older bibs are used on the turbo if the pad still feels OK.
Crashing is usually a far bigger threat to your kit, it's possible to overthink the whole thing.
RTW
by RTW
ico wrote:
Sat Feb 23, 2019 6:44 am
It is salt water, and over time it rots it. This is true of most fabrics. Think about rinsing wetsuits. It’s the same thing.
GaBa
by GaBa
I used to only use assos or some other sport specific detergent. No softneres. Now I added vinager and boy oh boy, before greyish socks are now white, same with skinfoils, also smell much nicer. Good advice :beerchug:
Alexandrumarian
by Alexandrumarian
GaBa wrote: I used to only use assos or some other sport specific detergent. No softneres. Now I added vinager and boy oh boy, before greyish socks are now white, same with skinfoils, also smell much nicer. Good advice :beerchug:
Are you saying that greyness was reversed? I have white assos arm warmers and castelli socks, both turned to a horrible greije after the first wash.
uraqt
by uraqt
There is a post here, somebody had an old bottle that had the active ingredients listed and found matching soap that had the same active ingredients.
It was years, years and years ago I tried to find it but no luck...
Sorry
C
