Clavicula Classic with 9100 Front Derailleur
HugoDrax
by HugoDrax
Good evening, I have a set of Clavicula Classic cranks with Praxis 50/34 rings and a Shimano 9100 front derailleur with a 34.9mm band clamp on a frame with a traditional English BSA bottom bracket from THM.
My derailleur appears to run into the frame and not allow the easiest gear to be used without rubbing. I could adjust the derailleur to be slightly crooked, but I fear shifting performance will suffer.
Have you gotten this setup to work? Do you have any tips for adjusting the front derailleur?
Thank you for your help!
