Wheels Manufacturing BB Insert
Bordcla
by Bordcla
Which of their models do you recommend? They have versions that seem to be simply pressed (one half into the other) and other versions where both halves are screwed into one another. Is any of the two preferable over the other and, if so, why?
As regards bearings, I'm hesitating between their ABEC-3 version and their angular contact bearings. Not considering the $125 pricier ceramic bearings. Of the two I'm considering, which would be better, and why?
This is to replace the BB86 pressed in bearings in my Canyon, which have developed an annoying "ticking" sound at about 3000 km only...
Jugi
by Jugi
To replace a klicking or ticking pressfit bottom bracket, go for the screwed into one another -model. That’s an upgrade and will most likely get rid of the noises. A pressfit is just a pressfit, the bearings may be higher quality but the original problem (which causes the unwanted noises) does not get resolved.
jlok
by jlok
I have been using their Thread Together BB. Good stuffs. Even the cheapest abec3 bearings are smooth.
NickJHP
by NickJHP
I've installed several of the thread-together models, and they've all been completely trouble-free since installation. The oldest of them has probably done about 30,000km by now. I use the model with angular contact bearings, as (provided you set the preload correctly) the load is shared across more of the balls.
naylor343
by naylor343
Worth a look here:
https://www.hambini.com/bike-parts.html
Also look through his blog and YouTube videos, if you want to know the pros and cons of different bearings, this is your guy.
bat82
by bat82
naylor343 wrote:
Wed Aug 15, 2018 9:44 am
Worth a look here:
I second this.
I have Hambini's PF30 to Shimano BB in my 2013 Cannondale Evo Black Inc. Noticably stiffer BB, no more creaking, ultra smooth spinning. My cranks now spin like it does in all those fancy YouTube vids of bikes with Ceramic Speed bearings and oversized pulleys. Except Hambini's solution is a lot cheaper, easier to service and maintain and actually works when loaded / under stress.
I highly recommend his cycling related YouTube content. Gives a good perspective on much of the bike industry's marketing b/s.
ms6073
by ms6073
Worth a look here: https://www.hambini.com/bike-parts.html
Wish he would make some more of the Shimano BB86 Racing assemblies.
nycebo
by nycebo
jlok wrote:
Wed Aug 15, 2018 5:14 am
I second this. I LOVE the thread together BB with the angular bearings. No need for overpriced ceramic.
nycebo
by nycebo
Worth a look here:
Damn you. That bottom bracket, especially in bright orange, is STUNNING.
Quick question on installation: Any concerns about pressing through to the other side from the inside? Is it easy to align?
ms6073
by ms6073
nycebo wrote:
Wed Aug 15, 2018 3:28 pm
Have you watched the Hambini installation video? While I cannot speak to the Hambini BB, I do have experience with BBInfinite, which has a similar installation process. You will need a reasonably good quality tool for pressing in the assembly but you should first check to make sure there are no obstructions such as molded cable guides or cable guide screws/bolts protruding into the channel. Also check the faces inside the bottom bracket for sharp edges that might snag the bb assembly while pressing in and if there are sharp faces, use an appropriate tool to try and round them off.
jfranci3
by jfranci3
I just replaced my ticking BB86 press fit with a Shimano PF unit. It's already creaking. I cleaned it with acetone, then 90% alcohol used loctite, rechecked the install/press, and it is still creaking. I'm going to try to treaded units now.
Note on the threaded units, if you're DIY - you need two x 16prong FSA MegaExo / Shimano 9000 tools.
Ceramic bearings are a waste of money. The advantage would be longevity in clean environments and marginal savings (1-2w) under high stress (sprinting). Your grease gets contaminated on your bike bearings with dirt and moisture, erasing these advantages. You'll be super OK with the ABEC-3 units. Angular contact would be a short term performance advantage, until the grease ruins things, assuming you can get the lateral load OK. Looking at the bearing seals and probably lateral adjustment would yield more results than any bearing type difference.
nycebo
by nycebo
ms6073 wrote:
Wed Aug 15, 2018 3:37 pm
I did and it went very smoothly. I just wondered how actual users' experiences progressed. Your advice is well heeded. I wish the BB86 in bright orange were in stock. :cry:
bat82
by bat82
nycebo wrote:
Wed Aug 15, 2018 4:00 pm
My installation went as smooth as it does in his video. I used a home made press and the installation tool that comes witht the BB.
ms6073
by ms6073
My first try with BBInfinite was what spawned the comments in my previous post, but subsequent installations have gone rather smoothly by comparison.
Js2
by Js2
I recently installed hambini one on my Tarmac SL6 (bb30 to 24mm shimano), very high quality and precise fitment. :thumbup:
