Any SRM Origin owners in the house?
Quarq Dzero without rings is 560g and Origin is 520g roughly. I've had 6 Quarqs and broken 4 of them, so....
Ah yeah, it's not boatloads lighter than your other options and the price is on the steep side.
I've had two Quarqs, both with issues. First one broke, second one would display wacky power if there was any moisture on the ground.
The origin has been flawless so far, but if I'm honest with myself I bought it mostly because I like the way it looks.
130 BCD? Because 110BCD version is 530g (+/- 3): 410 for cranks, 120 for the spider (NHB in this case).
Hopefully the new circuit board will have some active temperature compensation like pretty much every power meter on the planet has these days. Blew my mind when I read that SRM hadn't implemented that yet. Can't help but be pessimistic about the future for that company. Being reliable is one side of the coin, giving good quality data is another. I've had 2 Quarqs and neither broke or burst into flames.
Yeah that THM arm is ugly as sin but did you really expect them to make a mould for the incredibly small intersection of people that ride 165s and are willing to shell for their arms?
Errrr, no.
I've had two DZero's on the scales this week.
110BCD / 175mm / BB30 - 541.4g
110BCD / 172.5mm / BB30 - 534.9g
110BCD 50T Carbon Ti X-CarboRing - 81.3g
110BCD 34T Carbon Ti X-CarboRing - 29.7g
So the 172.5 DZero & compact CarboRings = 645.9g
As for reliability, used my DZero pretty much daily for 18 months without a hiccup. It's been so good, I've just bought another.
I'm not flaming SRM here, just pointing out the crazy price for not a lot of weight saving. And that 165mm crankset is just appauling.
IG: RhinosWorkshop
IG: RhinosWorkshop
Sorry weight included spacers.
Need some help from the SRM Origin owners here. Can anyone help to take a photo of your installed SRM Origin on your bike to see whether there are small holes surrounding the spindle on the drive side? There is a slim spacer thing that came with the SRM Origin, is that suppose to be on the drive side to cover up the holes or on the non-drive side?
I’m not sure what holes you’re referring to but the spacer goes on the non-drive side. As for the LED, I’ve never encountered that. When charging the LED should be solid red and turn solid green when fully charged.
I’d be directing these questions to SRM directly.
This is good to know. When I plugged it in the LED blinks red. It left it overnight and it is still blinks. It never turn green. Typically how long woul it take to full charge the unit? Since it is USB, I assume it will work with any other standard USB plugs from iphone or ipad or Garmin?
There is a spacer kinda thing on the spindle as shown below. I am not sure whether it is a spacer. It doesn't look like a typical spacer. I was wondering whether it is a cover for the holes at the end of the spindle on the drive side.
Yeah as Calnago mentioned I would put in a call into SRM support. I’ve never encountered what you’re showing in the pic or the charging situation you’re describing. Normally it takes 5-6 hours to charge fully. Btw here’s the manual from SRMs site.
http://www.srm.de/fileadmin/user_upload ... 4mm_EN.pdf
Charging I ssue resolved. It seems there maybe some contamination on the charging connector previously which prevented the charging connection to establish. A quick clean with cotton swap solved the problem.johnrho wrote: ↑Fri Aug 30, 2019 5:27 pmYeah as Calnago mentioned I would put in a call into SRM support. I’ve never encountered what you’re showing in the pic or the charging situation you’re describing. Normally it takes 5-6 hours to charge fully. Btw here’s the manual from SRMs site.
I am still wondering what that piece of spacer looking thing is. Do you have that with yours? What it suppose to do?
