Selle Italia SP-01 CRACKED !!!
BlackMambra
by BlackMambra
My Selle Italia SP-01 Tekno Superflow just collapsed ! :oops:
I have been using it from less than 2 months and when I was washing my bike I saw that both of the "flexing" sides cracked!
I am a 80kg rider ( 10kg less than the limit) riding only in good quality pavement and the bike was assembled at a Pinarello Dealer following all the intructions (I have a 2018 F10 DA DI2) !
I have just talked to my bike fitter and he said tha this is the 3rd saddle that he saw broken! Mine is the top model full carbon but he said that he saw the same thing happening with the plastic model !
Contacted Bike24 and Selle Italia but no response yet !
This is one of the most expensive saddles in the market and i am glad that I saw the crack while not riding the bike!
Anyone else had the same problem?
Frankie - B
Administrator
by Frankie - B
Great first post on any forum. :s
Honestly, i understand your feelings, I have been there as well. But i feel you cannot post something like this if selle italia haven't had time to respond. Please let us know how they follow up.
Please follow me on Instagram
BlackMambra
by BlackMambra
Frankie - B wrote:
Mon Aug 13, 2018 7:13 pm
Why not? Did i say that the saddle is a crap or said bad things about Selle Italia? I just posted the problem asking if anyone else had the same problem! I didn´t ask for web forums posting advices either!
gramsqueen
by gramsqueen
Maybe your saddle was too high and so the torsion from your inner thigh and opposite glute cracked it.
Also did you check the torque
BlackMambra
by BlackMambra
gramsqueen wrote:
Mon Aug 13, 2018 7:55 pm
All the screws were torque read tightened and I made a RETUL bike fit so i can assume that the sadle was in the correct position!
DJT21
by DJT21
Yes, RETUL bike fits usually put the saddle too high.
corky
by corky
Do a search of the forum......and yes you’ll see it’s not the first example.
Hope that helps......oh and welcome to the forum
BlackMambra
by BlackMambra
DJT21 wrote:
Mon Aug 13, 2018 8:03 pm
Ok. Thanks for your tip but for me if this reason could cause a failure like this that is just unaccetable for such a claimed High Performance product.
But thanks again !
BlackMambra
by BlackMambra
corky wrote:
Mon Aug 13, 2018 8:20 pm
Thanks ! I did the search but didn´t fund someone that had the failure in the flexing wing.
Wookski
by Wookski
I’m < 64kg and have broken a couple of saddles- although much more exotic/ lower weight than this one. My point is that these things happen- the important thing will be how the retailer addresses the issue. Good luck!
Next time get a Berk. Much lighter, nicer and if your big ass brakes it you can be confident that you will be looked after.
Alumen
by Alumen
Last year I cracked my Fizik Antares R1 (full carbon) at the point of the so called flex wings during a ride. We have only good pavements here as well. According to Strava I did about 2.400km's with the saddle until it cracked..
Though I weigh around 90kg, I was a bit disappointed since I thought that a carbon saddle should be stiff and reliable.
Lessons learned..., no lightweight carbon saddles for me anymore. I have also owned once a Selle Italia SLR saddle with Ti rails on my MTB and with that one the rail cracked (which was more likely given the track I was riding).
So now I ride a Flite TM Flow now, ~230gr with a nylon shelf and manganese (= steel) rails. Maybe a few grams (~60) more compared with the Antares, but it is equally stiff compared with carbon saddles (I have owned a Flite Kit Carbonio as well) and still comfortable. And I have full confidence in my saddle now.
CAAD 13 105 Disc
CAAD 10 2015 R.I.P.
mdeth1313
by mdeth1313
Wookski wrote:
Mon Aug 13, 2018 8:44 pm
your big ass brakes
:no1:
Speedplay is the devil!
Alexandrumarian
by Alexandrumarian
Alumen wrote:
Mon Aug 13, 2018 9:48 pm
I guess you had a bit of bad luck... Maybe stay away from the sub100 saddles but mainstream stuff such as fizik are pretty sturdy . Personally I used an Aliante 00 for almost 3 years with some pretty nasty pothole impacts under my 95-98Kg and no problems at all.
Wookski
by Wookski
The strongest saddle I have ever used is the 70g wr compositi- very simple design where the rails are formed from the carbon shell.
Downside is that there’s little to no flex so the fit needs to be spot on.
KotP
by KotP
It's a good thing it's new then and Selle Italia have a 24 month wararanty.
I had a SLR that cracked, laterally along the saddle body, after 22 months of extensive use. I'm light so not sure what happened.
I emailed Selle Italia, they wanted to inspect it for QC purposes, and I had a brand new replacement saddle about a week after they received it.
It was a waste of my time dealing with the retailer, who then wanted to pass responsibility on to the distributor, who wanted nothing to do with it.
This sounds like a ringing endorsement for Selle Italia, but honestly it was the easiest and most trouble free experience I've had when something went wrong with a product.
BlackMambra wrote:
Mon Aug 13, 2018 7:05 pm
Probably a bad time of the year for this to happen, I don't think you'll get a quick (or maybe any) response from Selle Italia for much of August. Better wait until September, or deal with Bike24.
