Ride with a loose headset: risk of some dangerous?
calpartz
by calpartz
Is it "normal" that the headtube is in such a condition?
The cross-sections are not superficial, but rather a bit deep, it can be "scratched", the fingernail "goes a bit in". The same is for some vertical-sections.
mattr
by mattr
Not sure what you are showing us.
Yes, that's a carbon head tube.
Yes, that's what they look like.
calpartz
by calpartz
mattr wrote:
Wed Aug 22, 2018 7:46 am
A friend of mine just wanted to know if this condition of the head tube is normal (since for example the cross-cut and some vertical-cut are a bit deep).
mattr
by mattr
Cut?
Thats the edges of the pieces of carbon. There's no cosmetic top layer on a steerer.
That's pretty much what your frame would look like with no cosmetic layer or clearcoat/paint.
calpartz
by calpartz
mattr wrote:
Wed Aug 22, 2018 7:51 am
Cut?
Thank you very much for this answer.
So, for you it is not broken and it is absolutely safe to ride, right?
Stitchking
by Stitchking
If you've damaged it it will be evidenced by a compressed ring in the carbon around the area where the compression washer contacts the fork (top bearing).
Sent from my SM-G935F using Tapatalk
calpartz
by calpartz
Stitchking wrote:
Wed Aug 22, 2018 7:57 am
Ok, I understand and It sounds to me convincing!
In the meanwhile these pics were emailed to Canyon for an answer.
calpartz
by calpartz
Canyon says that the condition is so as it should be: absolutely normal!
That deep cross sections are normal, they come from the process of "baking" (or "cooking"?) of the fork in the chimney (is that the right word?!).
