Help me spend money (Soma Smoothie build help needed)
Toby
by Toby
It's not that it's too loud; it's just not to my taste. Neither is the green. Nor the Black Mountain. I'm really curious though, about what makes everyone so negative on the Smoothie when the reactions in the "rainy day race bike" thread were so positive.
The Goodship frame could have potential, but they're out in 56 in the orange and the full build is SRAM.
Are all these lower-priced steel options really worse than an R2? Bearing in mind that a more expensive steel frame isn't happening. Sadly.
mpulsiv
by mpulsiv
Toby wrote:
Mon Aug 13, 2018 11:47 pm
I'm not negative about Soma. Like I said I almost bought one but steered away due to limited tire clearance.
If you plan to ride in foul-weather, prepare to strip Soma every season and spray it thoroughly inside the tubes with frame saver www.jensonusa.com/JP-Weigle-Frame-Saver-Aerosol-Can
Mr. Pink frame is treated with "Electrophoretic Deposition". This coating acts as both a rust preventative inside and a primer out.
Toby
by Toby
mpulsiv wrote:
Tue Aug 14, 2018 12:05 am
Oh. I live in Austin (and as alluded to, am really a tri geek); on the occasions that the weather's bad I stay my butt indoors on the trainer or run. Or swim. Riding in the rain happens when it's unexpected and catches us out, which happened just a couple of weeks ago but the overwhelming majority of our riding is HOT and unreletingly sunny.
I had almost decided on the Smoothie before this thread, now I'm all ruminating.
Nbriles2000
by Nbriles2000
There is nothing wrong with Soma's really. They're just overbuilt and kinda heavy (even for steel) but that's really pretty standard with most modern production steel frames.
The heavier gauge tubing is technically more "bombprof." I think manufacturers make them this way purposefully because they assume that's what the people who buy steel frames want.
This thicker tubing also can lead to what people describe as a "dull" ride quality. Thinner tubing is often described as "lively" and Jan Heine has a lengthy article about a phenomenon called "planning" in which the bike has just the right amount of flex and helps prevent power loss.
Whether you believe that or not, this is still weight weenies and a lighter frame is rarely a bad thing!
Frameset material is important when it comes to ride comfort, but tires are everything. If I was going for comfort, I'd take a gas pipe steel frame with 650b x 42 over a Soma with 700c x 28mm.
I think another great option for you is a Soma Fog Cutter. Way bigger tire clearance than the smoothie and still pretty inexpensive
mpulsiv
by mpulsiv
Nbriles2000 wrote:
Tue Aug 14, 2018 4:19 am
I agree with you about thinner tubing. I'm no expert when it comes to steel, but this a good source www.strongframes.com/tubing-information to learn about tubing, however tubing diameter is not listed because it's up to the builder.
Soma Fog Cutter is disc only and same tubing (e.g. 4130 Tange Prestige) as Smoothie.
I don't think OP is seeking anything wider than 28mm. Throwing 650b into the mix is very much gravel specific.
Smoothie and Mr. Pink are the most affordable that I came across. Gunnar Sport is great frame http://gunnarbikes.com/site/bikes/sport. I don't remember the source but it's at least 200 grams lighter with True Temper OX Platinum tubing. Nice paint jobs, custom paint is also available. Last I checked, it was $1200 for frame + $400 for carbon fork.
I won't mention frame weight of my Mr. Pink. If you find out, you may steer clear from any steel frame :beerchug:
Toby
by Toby
Thanks all for the extra details.
Yes, of course all else equal I'd rather a lighter bike, but the budget is what it is, and much as I'd love a Stinner Gibraltar it's not going to happen, because the upper bound for this is the R2. I had also come across the Gunnar but that faces the same problem: $1600 for the frame & fork means that the only way to finish it under budget would be with 105 at best, and that probably still wouldn't work in the end. Money over that is to make sure the race bike gets Di2. Heck, for the price of the Stinner frame alone I could get the R2 and the correct native Quarq instead of needing to adapt the BSC one I have.
The Goodship frame & fork for $600 would be a bonkers good buy, and maybe I should see if I can scare one up. They're out of my size though, of course, and I assume any restocking will be next year's model for retail.
Not interested in disc brakes for now. Maybe for the next set of bikes. And 650b has the same issue: one of the goals here for sticking with 700c and rim brakes is to continue to use our library of wheels. Again, while I'm sure they're comfy, 28s will be a lot nicer than 23s.
I even would have considered the BD (boo hiss, yes I know) Motobecane Gran Premio Pro. Reynolds 853, R8000, a decent paintjob, and I can toss out a crummy FSA crankset instead of a nicer one. The problem is it specifies "clearance for most tires up to 25c", which isn't enough.
Bah. Maybe the R2 is the best deal here.
Nbriles2000
by Nbriles2000
I actually thought a lot about that motobecane, too. I actually just bought a Raleigh Grand Vittesse on a whim because there was a fantastic deal on their corporate site. Also 853, but with 6800 Ultegra. I'm currently working on replacing stock junk parts to get the weight down and after I replace the 2kg wheelset I think it's gonna be great.
It's pretty similar to the Motobecane, but there are reports that it can fit 32's
BritishV8
by BritishV8
I stumbled on this thread, and decided to correct misinformation in it.
I've built a Soma Smoothie and I'm currently running 32mm Conti Grand Prix 4 season tires on it. They've got plenty of clearance, regardless of tire pressure! No, I don't have to deflate my rear tire to remove or reinstall the rear wheel.
Perhaps Soma's website causes confusion. They sell frames and forks separately. For Smoothie, they offer two different forks. I'm using Soma's lugged steel fork, but they also offer a carbon fork (rated for 28C tires). So, if you want carbon fork with clearance for 32c tires, select one from a different source.
My Soma Smoothie is size 62cm. Soma also offers a size 66cm version. Someone mentioned Ritchey's Road Logic as a good alternative to the Smoothie. I like that model, but apparently Ritchey doesn't offer Road Logic in any size larger than 59cm... so I guess they'll never sell me one.
Tychom
by Tychom
BritishV8 wrote:
Mon Jan 14, 2019 3:31 am
Not much point reading off 59 vs 62 as that can mean anything at all depending on the manufacturer in question.
Soma Smoothie 62 Stack/Reach: 619/396.
Ritchey RL2 59 Stack/Reach: 609/410.
There's barely anything in it considering the Ritchey is a long and low race frame whilst the Soma is not.
