Would you like to see the mist around Road tubeless cleared? (help me!)
Do you guys think you need a manual for setting up and understanding road tubeless?
Poll ended at Thu Aug 16, 2018 9:19 pm
Yes, PLEASE!
24
50%
Nah, already know it.
24
50%
Total votes: 48
kode54
by kode54
exactly. if the standards were all the same with less variables...I'm sure you would've had more folks on tubeless way back. My first try at it was dismal...couldve been the rim or the tire, but nevertheless, it was enough for me not to adopt tubeless on my road wheels early on.
stiffnezz1 wrote:
Mon Apr 22, 2019 2:22 am
TobinHatesYou wrote:
Wed Mar 13, 2019 10:01 pm
mag wrote:
Wed Mar 13, 2019 9:37 pm
Looks like there's finally some tubeless standard coming
https://road.cc/content/tech-news/25764 ... atters-you
TL;DR version: It's UST.
dont know why none of the other big players adoped road ust that was announced over a year ago. Dont know who is out there pushing for ISO and ETRTO standards update but they are the real MVP in the tubeless game.(probably Mavic)
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Chebacco + DA9170 + Enve G23 CK CL hubs
- Allied Able + DA9170 + Enve G27 CK CL hubs
mr2scott
by mr2scott
Calnago wrote:
Wed Mar 06, 2019 4:08 am
It’s not “fud”, it’s reality. Was at a shop today and the guy was admiring my tubulars. Rather than singing praise about tubeless, he instead was saying how tubulars are actually easier than tubeless these days on the road. He said that setting up tubeless for their customers often is a two man job to get the tires on the rim. I couldn’t help but think how this is the hot tubeless topic right now on this forum.
That guy at the shop sucks at putting on tires. I change hundreds of tires a month. I'd rather install tubeless any day over tubulars. Tubeless tires are almost never hard to mount. I had one issue with a prototype tire on a stans wheel, we needed 4 hands to get it on, but that was a wierd one off thing.
TobinHatesYou
by TobinHatesYou
GP5K TLs were very tough to mount on my 5.6s, but it was in no way a “two man job.” It just meant as had to use a distressing amount of force with a tire lever. No big deal, I’ll just skip GP5K TLs next time and buy more Fusion 5 11Storms or some other tire that can be mount/removed without levers.
MikeD
by MikeD
TobinHatesYou wrote:I have none of your issues.
6) The best tape is the green powder coating tape (3M 8992 or generic.) The best sealant is Orange Seal.
How do you get the tape to the right width? I need 21 mm and it doesn't come in that width. The closest is 1" (25.4mm).
ms6073
by ms6073
MikeD wrote:
Wed May 22, 2019 4:28 pm
[/quote]
My guess would be to apply the tape centered in the channel, then once wrapped, use a shop knife, exacto knife, or razor blade to trim the excess.
TobinHatesYou
by TobinHatesYou
What are the dimensions of your rims? I use the 1” tape on both 19mm and 21mm rims.
MikeD
by MikeD
DT R460, 18mm.
The owner of my LBS says to use narrower Stan's tape and overlap it. He says he gets no air bubbles and it works fine. I'm worried about the sealant working its way under the tape, which is minimized by using the proper width tape, so I've not tried that.
K4m1k4z3
by K4m1k4z3
You use a scalpel / exacto knife to trim the tape before applying it. Lay the roll on a table and cut it while rotating the roll.
Giant TCR Advanced Pro 1 Disc '18
