Sram red crankset gxp with qrings VS new rotor aldhu oval
seaneT1
by seaneT1
Hello! I am torn between those two options for a new crankset and I wanted to hear your opinions as well on which might be a better choise. :)
wheelsONfire
by wheelsONfire
Rotor uses a 30mm axle, two axle versions available (different chainline)
Red GXP uses a 24mm axle, or something like that.
What BB standard is your frame, what groupset do you have?
Is your frame the new through axle for disc brakes type?
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
syplam
by syplam
and I am torn between etap quarq and rotor Dm 2inpower haha
Sent from my SM-G9650 using Tapatalk
seaneT1
by seaneT1
wheelsONfire wrote:
Tue Aug 07, 2018 5:57 pm
I have a BB86 or something like that I think, will check soon, rim brake type, currently have a shimano ultegra crankset and the rest of the groupset is sram red etap. I had bought a sram red bb30 crankset in the past, but the axle was way too sort to fit.
TobinHatesYou
by TobinHatesYou
With BB86, I would stick to 24mm crank options.
wheelsONfire
by wheelsONfire
If you have Etap there is no reason not to go for Red crankset. I wouldn't use Rotor in this setup and certainly not oval chainrings!
Etap FD has been reported not to work well with oval chainrings.
Bikes:
Ex bike; Vial EVO D
