Sprint shift work around with 9170
ParisCarbon
by ParisCarbon
Been researching on here and online.. but looks like there is no way to use the r610 sprint shifter with the 9170? I emailed Shimano and the reply was a picture of the SW 9150... isn't that kind of well "bulky" to be in the sprint position? With the movement to disc, keep seeing old sprint switch appearing... Sagan had it on his Venge at the tour as well as a few others..
PaulH
by PaulH
You have to hack a climbing shifter and solder the wires to the contacts , then water proof , there is a thread on here some where
Cemicar
by Cemicar
Likes of Sagan, Kittel, Gaviria must have used SW-R9150 for their bikes and still won many stages in Tour de France. I don't think the shape is identical to SW-R610, nor is critically different.
ms6073
by ms6073
Cemicar wrote:
Mon Aug 06, 2018 3:19 pm
There is no hack required to use the SW-9150. Although the shape different and the switch has a larger footprint, based on my experience using them with Enve SES Aero road bars mounted on the underside of the bar at the base of the curve to the drops, once wrapped with bar tape, the switches are not obtrusive.
- Michael
jlok
by jlok
The SW-R9150 switches come standard on my Propel Adv SL Disc. They are mounted above the thumb position at the drop. Good place to be, not obstructive.
TheDoctor
by TheDoctor
PaulH wrote:
Mon Aug 06, 2018 2:24 pm
It's here:
https://weightweenies.starbike.com/foru ... 3&t=151321
With this hack you can mount microswitches just about anywhere.
Specialized S-Works Tarmac SL6 Disc https://imgur.com/qudfWnI
Cervelo R5 Disc https://imgur.com/nbCQyR5
Argon 18 Nitrogen
Canyon Exceed CF SLX 8.0
Felt Decree 1
ParisCarbon
by ParisCarbon
jlok wrote:
Mon Aug 06, 2018 4:00 pm
Do you happen to know how they were connected to the bar? Just double sided tape? The old 610s had a band that wrapped around the bar as well..
Thanks!
ParisCarbon
by ParisCarbon
TheDoctor wrote:
Mon Aug 06, 2018 4:28 pm
It's here:
Thanks for the link...that looks a little more involved than what I want to get into :shock:
ParisCarbon
by ParisCarbon
Go about half way down the page... is that not the old sprint shifter?
https://road.cc/content/tech-news/24483 ... enge-video
sun
by sun
Thanks for bringing this up. I've been wondering the same and tweeted to Shimano last night. I ruined an R610 sprint shifter wire in a crash. I soldered it together and it wasn't very easy as the wires are so small. I'm hoping their is an out of the box solution.
ParisCarbon
by ParisCarbon
sun wrote:
Mon Aug 06, 2018 5:25 pm
It looks like the only solution is the new SW-R9150. I did find this link for mounting it as a sprint shifter, its in Japanese, but on Google I just right clicked and hit the translate option:
https://www.cycle-yoshida.com/pc/syousa ... E=00641856
Its 3M VHB 2mm aircraft tape... its not cheap stuff! I work for an airline, so Im gonna see if the maintenance boyz have anything...
Cemicar
by Cemicar
ParisCarbon wrote:
Mon Aug 06, 2018 5:00 pm
Admit it more looks like SW-R610, but who knows.
ST-R9170 and 8070 don't have a port for that so casual users can't use SW-R610. However manufactures are known to make 'pro-only' stuff sometimes and I'm not surprised Sagan was offered special shifters by Shimano.
Can't fathom why there even exists such a sprinter-switch specific port to begin with.
ParisCarbon
by ParisCarbon
Cemicar wrote:
Mon Aug 06, 2018 6:38 pm
Yep.. Shimano is famous for this... especially with the CX 46T specific DA chainrings... good luck for the average street guy getting hold of that!! A top pro CX racer told me through chatting facebookt to just stop by the van and he'd give me one... too bad Im in Canada... :( Im gonna order a set of the R9150s for my CX bike.. Im so used to having a sprint shifter in the drops now I feel lost without it.. Im sure work has some crazy double sided tape I can "borrow"
ms6073
by ms6073
ParisCarbon wrote:
Mon Aug 06, 2018 5:55 pm
Seems a tad overkill considering you can get 3M double-sided automotive tape or Gorilla 6055001 Heavy Duty Double-Sided Mounting Tape from Amazon for less than $10 US.
I doubt it. If you look closely at that image in question, I can see the outline of the 9150 switch body.
- Michael
mattr
by mattr
It's extremely cheap.
AFAIK the only difference between "aircraft grade" and everything else is use by dates, traceability and storage controls.
So I can buy the shaped tabs for very little and rolls for not much more.
Usually buy in 1mm thickness though.
Just search for 3M VHB circles.
(Used to be able to pick up rolls at work, it's all preapplied/precut now. So no rolls available. :( )
