Upgrade for road bike - BB bearings and Rear Pulleys
What is best worth of money to upgrade with lower friction bearings for bottom bracket and rear pulleys?
Are oversizde pulleys good - or they just make shifting worse?
Kogel bearings?
Cycling ceramic?
KCNC?
thanks
Kogel bearings?
Cycling ceramic?
KCNC?
thanks
- VTR1000SP2
I’ve not heard of OSPW negatively affecting shift performance. I have tried a few options out there and here’s how I rank them:
Pulleys:
Value: tacx ceramic
Performance: OSPW coated
Weight: Kogel NFI
B.B:
Value - Hawk Racing
Performance - couldn’t really tell (Kogel vs CeramicSpeed vs Hawk)
Pulleys:
Value: tacx ceramic
Weight: Kogel NFI
B.B:
Value - Hawk Racing
Focus Izalco Max - 4.84kg without pedals
Cervélo Áspero - 8.28kg
Trek Madone SLR Rim - 7.73kg
Standert Triebwerk Disc - 8.47kg
None of them are worth it based on a watts/$$ calculation. You are talking about saving 1/2 to 1 watt. An aero road helmet can save you 10 watts.
https://university.trisports.com/2016/1 ... end-a-lot/
this discusses ospw in some detail https://www.velonews.com/2018/07/bikes- ... you_472956
the say it saves a bit less than 1% power, useful if you do tt, but unless you already optimised a lot of other things probably not the best roi
If you really want to go fast, get bearings without any seals and use a light oil for the lubricant. You'll have to re oil frequently but they will be the fastest.
Hambini Aeronautical Engineer, Polluting YouTube since 2016 - views expressed are my own...
- VTR1000SP2
Truthhambini wrote:If you really want to go fast, get bearings without any seals and use a light oil for the lubricant. You'll have to re oil frequently but they will be the fastest.
^ In the olden days () they used to do this for TTs (even in grand tours). If pro mechanics did it back in the day, I'd be inclined to trust it.
Edit: what happened to the smilies? <----The one above was supposed to be a normal one like this one Edit again: <-- that one is normal
Yup. Still can't find a smoother ride than Dura Ace hubs and Sugino BB with 1/4 inch bearing balls all around. They were so loose and fast
