Expander Plug
markdjr
by markdjr
I figured the expander plug was an easy place to save a few grams, I had read good reviews about the mcfk plug but I can't find one in stock. Anyone use or familiar with either of the Schmolke plugs from r2? Would they be a suitable alternative or something better out there? Thanks for any info.
Pop
by Pop
Tune gumgum (perhaps difficult to find), or extralite ultrastar
Enviado desde mi ONEPLUS A3003 mediante Tapatalk
Kayrehn
by Kayrehn
Am using the Schmolke plug, great weight savings because it takes the place of a plug and a cap simultaneously without the need of a bolt. It probably provides far greater support of the steerer tube too if that is a concern for you, as it is longer and has more contact area with the tube interior. Image
beanbiken
by beanbiken
Tried the Schmolke SL version of their plug. Could not get it to grip the inside of the steerer tube. The peaks of the alloy knurling were actually being blunted, put a pair of orings in the grooves and all good. Grabbed a Carbon Ti unit and no such problems. Also have the Extralite on another bike also with zero issues.
BB
BB
Coffee & carbon
Squashednuts
by Squashednuts
I'm just about to fit a new Schmolke expander and cap
Comes in a nice little boxImage
I was using an expander from JRC components, it's a similar price but like the @Beanbiken's experience the JRC became blunted and stopped gripping....this was after some time and being re fitted several times
Fuji SL 5.5kg tubs/5.9kg viewtopic.php?f=10&t=157704
Sold -
Focus Izalco Max Disc - Final Weight 6.7kg - http://weightweenies.starbike.com/forum ... o+Max+disc
beanbiken
by beanbiken
Yep that looks like the one, mine had a red bolt............. but other than that “appears"identical.
BB
BB
Coffee & carbon
jeanjacques
by jeanjacques
NiFTY
by NiFTY
Have ultrastars on 2 bikes, il issues.
qwpy
by qwpy
I use a cheap bbb brand expander plug to get the steering and headset tightened up as I like it.
Then i lossen the expander plug , take it out, and put in a tune gumgum.
tabl10s
by tabl10s
beanbiken wrote:
Tue Jul 31, 2018 7:08 am
BB
Which is the overall best?
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's).
2016 Rca: 11.07lbs/5.048kg.
2018 Rca.
2018 S-Works SL6 Ultralight: 12.03lbs.
ms6073
by ms6073
While probably not as lite as the Extralite Ultrastar, my vote is for the Cane Creek EEnut.
bilwit
by bilwit
NiFTY wrote:
Tue Jul 31, 2018 12:02 pm
same, though I have to say the design doesn't give me the most confidence ever (Extralite being notorious for parts "pinching" into carbon)
beanbiken
by beanbiken
tabl10s wrote:
Tue Jul 31, 2018 2:54 pm
BB
Best???? I would say I am most comfortable with the Carbon Ti, spreads it force over a greater area than the Extralite and has not slipped up till now..........
BB
BB
Coffee & carbon
PrinceEdward
by PrinceEdward
Thm fork with its expander plug, real genius
我從使用 Tapatalk 的 Pixel 發送
joejack951
by joejack951
What do you guys think of a design like the one in these videos? Yes, it's mine and yes, I need to finish the third video showing the bearing preload steps but you ought to be able to get the idea of how it will look when finished.
https://www.youtube.com/watch?v=WpDsfkyzLoI&t=2s
https://www.youtube.com/watch?v=Hj9Wi1hTw28&t=3s
