Stem/ Dropbar with integrated routing
bedampft
by bedampft
If've got a Giant Propel Disc, and I'm sick of that bloody compact dropbar. That thing is just to shallow and to short. So I'm looking for a stem/bar combo that has internal routing, which puts the wires down into the toptube behind the headset. Is there any such product?
The bike is awesome, but that dropbar drives me nuts.
MediumSizedMonster
by MediumSizedMonster
I just set up a new Allez Sprint with the Pro Vibe Aero Cockpit/stem.
Really like the bars ergonomically and they are very stiff.
MediumSizedMonster
MediumSizedMonster wrote:I just set up a new Allez Sprint with the Pro Vibe Aero Cockpit/stem.
Not sure if it completely accomplishes what your looking for but it’s got internal cabling and the stem has a couple interesting ports underneath that I don’t use.
dorin
by dorin
Look at BMC ICS stem with Vision METRON 4D flat, that’s what I’ll be using on the new bike and I have full integrated cabling.
cajer
by cajer
dorin wrote:
Mon Apr 29, 2019 8:30 am
Will the BMC ICS stem work with other bars or work on bikes without fully integated cable routing? I have an old Cervelo S5 that I want to put an integrated bar stem on.
dorin
by dorin
cajer wrote:
Mon Apr 29, 2019 8:46 am
No idea, for me it allows the cables to go inside towards the fork tube
fasdflkjweorinjs
by fasdflkjweorinjs
I'm really encouraged by the new FSA ACR stem, headset and bar system but it seems to require special bearings. Would love to hear about all your experiences with it when it comes out.
dricked
by dricked
I’d like to switch to the Fsa acr setup but from what I’ve found the claimed weight is quite a lot. I’d like to have no cables showing but not sure the extra ~250g is worth it.
warp
by warp
Look at this thread...
viewtopic.php?p=1483787#p1483787
I made a very similar question yesterday and have very similar requirements (I can live the the short drop and reach, though).
The particularity of our bikes (I have a Defy) is that the routing is taken over and to the rear of the stem. Yes, it's a feature I do not love but even the wires/lines exposed without the cover for the stem look very clean if you don't want to cut the steerer.
I think the BMC system requires the BMC fork which is squared off at the steerer and not round. The Pro brand stem I think it requires to drill the steerer or something like that.
I seem to recall Canyon has noather integrated solution, but can't remember how it deals with the cabling. I bet is different from Giant.
My point is that you have to read carefully how each integrated system works.
You can use the stem from the Defy and pair it with any other bar that fits your requirement. I have only found the Pro Aero Vibe and Prime Primavera. Additionally to full Di2 compatibility, you need a bar with a hole in the back of the round section of the handlebar to feed the Di2 cables into the stem.
Imaking20
by Imaking20
Another vote for the Pro Vibe Aero. Works great on my Cento10 Air. Favorite aero bars to date!
Current:
Wilier Wonka | The Dentist | The Bucket List
Retired:
Specialissima | Evo | T2 | Blue | Project C6.0 | Felt AR FRD | Colnago C59 NERO | 2014 S-Works Tarmac | S-Works Venge | Wilier Cento Uno SL | Tarmac SL2
alcatraz
by alcatraz
Although this bend looks quite tight these chinese bars might be able to do what you want.
Considering that the housing will have to come out under the stem and make a bend on either side of the stem for whatever bar you choose it doesn't really matter that the cables exit before the stem or after.
Because they enter the frame on the top tube you can't avoid this little curve there. As long as they are close to the stem I think it looks pretty neat.
cajer
by cajer
Do you have a link to that bar?
alcatraz
by alcatraz
cajer wrote:
Fri May 24, 2019 7:43 pm
Check aliexpress for integrated bars.
