Recon Cassettes any good?
CraigKnobovitch
by CraigKnobovitch
Just want to hear some feedback from anyone who's owned one. Thinking eventually of maybe getting an 11spd steel or titanium one because of the look of them (also price wise on par or a little less than the RED or Dura Ace cassettes. I've heard that there's some durability issues, not sure if that's just for the aluminium one (obvious since it's a softer metal) or a general trend with them. Thanks!
markdjr
by markdjr
Second this, I've been eyeing a black one and would love to hear some feedback as well.
Bling
by Bling
I had a gold Recon cassette. It looked absolutley killer!
Most of the rings were aluminum, and I think the two smallest may have been Ti. The set up included the lightest model of KNC chain, and Sram Red rear dearilleur (tuned). It seemed like I had to constantly adjust the rear derailleur... Every 500km or so, ugh. I never ride in the rain or in harsh conditions that would necessitate frequent service. Once re-adjusted the bike shifted well again. Eventually I was fed up and tried a Red cassette, it worked flawlessly and my adjustment days were over!
I would definately try an all titanium cassette, I think the aluminum wore so quickly that constant adjustment was required.
_____________________________
I'm handsome
CraigKnobovitch
by CraigKnobovitch
Bling wrote:
Mon Jul 30, 2018 7:55 pm
Exactly my thinking, If I was to get one I'd only go for the steel or titanium. Aluminum isn't the best material to make cassettes out of
RyanH
by RyanH
I think some have had good success with the Omni Racer Ti cassette. I think it's lighter than the Recon at 118g for a 11-25.
Strava
Not for the sensitive types. My Instagram reviews
The Ex's: I've lost track...
Stendhal
by Stendhal
RyanH wrote:
Mon Jul 30, 2018 9:34 pm
My Omni Racer fell apart on a ride, sadly. The episode went into the "there are limits to weight weenie-ism" file.
Cervelo Aspero (7.75); Orbea Orca OMX (7.30)
Retired: S-Works Tarmac SL6, LOW// mki, Pinarello Dogma F10\F8, Lapierre Pulsium, TIME Fluidity, Wilier Cento1 SR, Ridley Noah, Cyfac Cadence, Cervelo S2\R3\R5, Felt Z25, Klein Quantum, Cannondale 2.0
alcatraz
by alcatraz
Alloy on anything else but the largest cassette cog is asking for trouble.
If you don't require much mileage out of it then it's an ok idea but then what is the point really.
Better stay with sram red cassettes. Chain skipping is annoying as it takes only one gear to skip to make the cassette basically useless.
/a
campagowlo
by campagowlo
I'm currently using a seqlite alu and its holding up very well. I've used an alu recon in the past and it needed a fair bit of constant adjustment and the teeth wore quickly.
WinterRider
by WinterRider
campagowlo wrote:
Tue Jul 31, 2018 12:06 pm
Curious to know.. if anyone can say if the al are heat treated?
Litespeed 2000 Appalachian 61 cm
Litespeed 1998 Blue Ridge 61cm
Fitness rider.. 1 yr from seven decades age.
That is my story and I'm stick'n to it.
Svetty
by Svetty
Don't know about alu cassettes but I have tried some made from Brie. They were fine until the sun came out ;)
RyanH
by RyanH
That's a bummer, how old was the cassette? What happened when it failed? Did you contact the retailer about it?
Strava
desperado95219
by desperado95219
I guess I must have been unbelievably lucky, but I have used exclusively recon alloy cassettes for 10+ years? Never had a problem! I have a gold one on my S5 and a black one on my Orbea. I generally get around 3,000 miles out of them. I always start with a new chain and keep my chain clean and well lubed. I live in California on the edge of the Sierras and do a fair amount of climbing, but very rarely ride in inclement weather. (I also use Fibrelyte carbon chainrings).
PrinceEdward
by PrinceEdward
https://bikerumor.com/2014/08/13/review ... not-right/
Better leave this alone
我從使用 Tapatalk 的 Pixel 發送
Stendhal
by Stendhal
RyanH wrote:
Wed Aug 01, 2018 3:57 am
Hi Ryan, thank you for moderting the site.
As I recall it was not brand new, probably <1000 miles used. Did not go back to the retailer because, among other things, I didn't think of doing that. It could have just been a bad sample or even installation error by me (although I did not think so because it was fine at first).
Kayrehn
by Kayrehn
Used the recon in the past, chipped 4 teeth even with careful/slow riding (zero sprints on it etc) and I dumped it. I think the Sram xg1190 cassette is good enough for most ww unless you want to do an all-out light build that wouldn't get much mileage. The rotor cassette is lighter still but who knows how long the rivets will hold the cassette together. So, the sram is really the best compromise.
