Is the "Oof" the sound you make after you get kicked in the ass?Starter wrote: ↑Wed Jul 25, 2018 1:36 pm@themidge- I’ll check out the Bontrager stem, thanks
@everyone else- I like to check in every couple of years to see if the forum has remained conquered by the trolls... I imagine I’m one of the few of the old guard that bothers to anymore. Of course more stem options that hid the junction box would be cool, and a nice workaround to spending a grip. And of course you trolls will deny it just to be trollish. Because, you know, you suuuuuck. See you Starbucks posing clowns in another couple of years. Toodles.
Better solutions to junction boxes for Di2/EPS...
2016 Orbea Orca OMR:
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
2015 Pinarello F8(build in-process).
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
- Powerful Pete
- Moderator
- Location: Lima, Peru and the Washington DC area - it's complicated.
Everyone simmer down - the topic raised is a valid one - let's stay on topic and avoid the personal bits. Thanks.
Supercommuter: Jamis Renegade...
Oldie but goodie: De Rosa Professional Slx, Campagnolo C-Record...
Er, I'm kind of with the OP.... ok, junction boxes are hidden today, but there are still exposed wires/cables (assuming you don't have one of the latest 'everything-runs-internally' frames).
That's why I went eTap.
It's 2018 after all... not 1999.
C'mon Campag and Shimano - we don't plug our computers into dial-up modems anymore.... why should we plug derailleurs and shifters into junction boxes and stuff???
Why should we plug in derailleurs and shifters, or associated batteries... at all, ever. Still haven’t come across an electric group that outperforms my existing setups, period. TT bikes excepted.
Ok, I know... I’ll show myself out.
If you're clever, you can hide the junction out of sight either under the BB or saddle and only see one wire running from the bars.
Not a dig at you necessarily, but I feel like this must be an iPhone generation thing. Working in IT, wires reign supreme. I can get 1 gigabit throughput with 0.2ms response times over LAN vs 20-50ms response times over Wifi and maaaaybbe 250+ mbps if I'm lucky. Let's not even get into mobile data. Anyway, coming back to cycling, I think response times are a limiting factor for eTap, which is why their shifting is perceived as slower than Campag and Di2. Also, you lose wires with eTap but it's still heavier than 9150...
By response time, I'm assuming you mean latency. If your wifi network has a latency that high, you have a seriously poor wifi network. Most properly setup wifi networks will have a latency of 2-3ms, even on a 2.4GHz channel. Wired is still supreme though, in both latency and throughput.
I suppose the slightly slower shifting of eTap is a tradeoff for a much easier setup.
--Sennder
Ha! That makes me feel young.... wish I was part of the iPhone generation but I'm 53 years old!
I've also worked 32yrs in IT... and yes, wires are great for Data Centres and such like, but we're not all sending mega-gobbles of data to our derailleurs every nanosecond and on bikes they're ugly and unnecessary.
eTap is prettier too. On a recent YouTube upload about the Rotor Hydro group, it was said that it could also be made electronic which be a game changer in terms of weight and operation.sennder wrote: ↑Wed Jul 25, 2018 7:40 pmBy response time, I'm assuming you mean latency. If your wifi network has a latency that high, you have a seriously poor wifi network. Most properly setup wifi networks will have a latency of 2-3ms, even on a 2.4GHz channel. Wired is still supreme though, in both latency and throughput.
--Sennder
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
A better topic title might help elicit better responses and help someone find the info in the future.Powerful Pete wrote: ↑Wed Jul 25, 2018 4:41 pmEveryone simmer down - the topic raised is a valid one - let's stay on topic and avoid the personal bits. Thanks.
Fair enough - I have changed the post title to better reflect the topic. Let us now all stay on topic, thanks. PP
- Similar Topics
- Replies
- Views
- Last post
Issue and solutions for thm fibula carbon spring
by PrinceEdward » Wed Aug 01, 2018 4:11 pm » in Road - 6 Replies
- 584 Views
Last post by PrinceEdward
Wed Aug 08, 2018 5:13 am
- 1 Replies
- 313 Views
Last post by Cemicar
Fri May 25, 2018 12:45 pm
- 3 Replies
- 858 Views
Last post by rlanger
Mon May 14, 2018 10:47 pm
- 4 Replies
- 508 Views
Last post by Noctiluxx
Mon Jul 16, 2018 11:59 pm
- 6 Replies
- 546 Views
Last post by kode54
Fri Aug 03, 2018 3:01 pm
