Press Fit 30 to BB86 Conversion
lord_brush
by lord_brush
As per title, can anyone advise on decent Press Fit 30 to BB86 conversion BB?
(Going into a Ridley Helium SLX)
The right to bear arms is slightly less ludicrous than the right to arm bears. (Chris Addison)
wheelsONfire
by wheelsONfire
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
lord_brush
by lord_brush
Thanks, hadn't thought of the Token offering. How would this compare with the Rotor conversions? I can get hte Rotor at more or less the same price. Is there much differnce in weight, durability etc?
nemeseri
by nemeseri
lord_brush wrote:
Mon Jul 23, 2018 3:28 pm
Can you be a little bit more clear on which one is the BB type and which one is the crankset? Is it a PF30 bike and a shimano crankset? In that case there are many great options out there. Consult with the BB manufacurer regarding the recommended compound between the BB shell and BB for the best result (i.e. aqua proof paste or loctite).
x) Wheelsmfg - from steel to ceramic bearings, plenty of good BBs: https://wheelsmfg.com/bottom-brackets/p ... e_dia=7121
x) Kogel: https://www.kogel.cc/collections/press- ... o-cranks-1
x) C-Bear: https://www.c-bear.com/en/products/bott ... face-rotor
lord_brush
by lord_brush
The frame is PF30, and the crankset is a Verve Infocrank.
I think Rotor do a specific option for the Infocrank, but at the same time, I believe it will work in BB86 with an additional shim? Thats how it is in its current frameset.
wheelsONfire
by wheelsONfire
I use Token now instead of Rotor. I think the fitting they've come up with is very good. It's really your call what bearings you wish to use.
I would suggest you read through the info at the Token link and you'll see why this is a good idea.
I thought of Hambini to, but this was a good choice.
Bikes:
Ex bike; Vial EVO D
nemeseri
by nemeseri
So based on the infocrank website there are two versions:
x) One with standard 24mm spindle and it's compatible with any shimano BBs (like BSA, BB86, BB90) without any shim or spacers. If you have this version, you can use the BBs I linked previously. (OR any PF30 BBs with proper shims)
x) The other one seems to be a propriatory Praxis M30 standard. Praxis offers BBs for PF30 frames: https://praxiscycles.com/product/m30-conv-bb30-pf30/
So check your crank to see if it's the 30 or 24mm spindle one and buy the BB accordingly.
I doubt that you have shims in your BB86 frame, given the BB86 standard only accepts a 24mm spindle. (The only way that you have shims currently is to have a BB86 shell, with rotor 4130 bearings reduced to 24mm with shims to accomodate the infocrank. But this is such a stupid setup I don't believe this is the case.)
lord_brush
by lord_brush
Sorry, when I mentioned shim I didn't actually mean a shim as such- it's a small washer that went on the non drive side to take up a tiny bit of lateral play.
I'm 99.9% certain my Infocrank is 24mm
scale29
by scale29
Hope also offer a solution for PF30 to 24mm. I fitted one to my wifes Focus Izalco Max.
