Pinarello Dogma F10 Build / Finished
wszs91
by wszs91
Finally received my frame last week, didnt have time to post before, but here it is.
Pinarello F10 200 bob frameset size 53
Mavic Cosmic Pro Carbon SL UST wheels
Sram Red eTap wireless groupset
Quarq Dzero Powermeter
Fizik Antares 00 saddle
Most stem, handlebar and bottle cages
Dura ace pedals
Total weight: 14.98 pounds
This came to replace my supersix evo 2017 (will be posting pics of that one ;)
Now its time to ride!
tabl10s
by tabl10s
Some say all black bikes are boring. Not when they're shiny and new.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's).
2016 Rca: 11.07lbs/5.048kg.
2018 Rca.
2018 S-Works SL6 Ultralight: 12.03lbs.
Bridgeman
by Bridgeman
Absolutely stellar build! Really like your choices.
I am of course biased. Every day I ride my F10 I just can't believe how good a bike ride can be.
Frankie13
by Frankie13
Beutiful ride! You mentioned its a 53, would you mind to share how tall you are? I'm 5.8 and would be debating between 51.5 or 53 frame size.
TonyM
by TonyM
Frankie13 wrote:Beutiful ride! You mentioned its a 53, would you mind to share how tall you are? I'm 5.8 and would be debating between 51.5 or 53 frame size.
Go for a bike fit as it depends also on the proportion legs vs. torso, your position on the bike, your flexibility, etc...
I am 5‘7 and decided for a 50 (but I could have also taken a 47 or a 51.5).
bryanhayes
by bryanhayes
Amazing bike - looks fast just relaxing!
What is your saddle height in the pics? I'm seriously looking at an F10 as well - not sure if I'm better off with a 53 or 54.
MRM
by MRM
TonyM wrote:
Thu Jul 19, 2018 8:38 pm
What Tony said. Most likely you will rather be a 51.5 than a 53 though.
wszs91
by wszs91
Frankie13 wrote:
Thu Jul 19, 2018 6:25 pm
Im 5'8.5, but have longer legs than people my height, so i went with 53, but im pretty sure i could use a 51.5 with a longer stem :D
wszs91
by wszs91
bryanhayes wrote:
Fri Jul 20, 2018 12:23 am
Current saddle height is set 75.5cm from Bottom bracket to saddle top on all my bikes, i use 172.5mm cranks
Stendhal
by Stendhal
I am so happy for you! I love my 167 Black Lava F10
Cervelo Aspero (7.75); Orbea Orca OMX (7.30)
Retired: S-Works Tarmac SL6, LOW// mki, Pinarello Dogma F10\F8, Lapierre Pulsium, TIME Fluidity, Wilier Cento1 SR, Ridley Noah, Cyfac Cadence, Cervelo S2\R3\R5, Felt Z25, Klein Quantum, Cannondale 2.0
fogman
by fogman
Very nice. I like it better than my 2017 F10 BoB with the diamond pattern on the fork and head tube. Your matte clear coat seems to have a little sheen to it. What length stem do you have? What is your saddle-handlebar drop?
@ Frankie13 concerning sizing. I am 5’8.5” with a saddle height of 73.3cm and 8.5cm handlebar drop. I ride a size 51.5 with a 110mm stem, 1.5cm spacers under the stem and a 17mm headset top cap. I also have swapped out my setback seat post for a zero setback seat post.
It's all downhill from here, except for the uphills.
KevinM
by KevinM
Gorgeous!
wszs91
by wszs91
fogman wrote:
Fri Jul 20, 2018 3:40 pm
On the picture i was using a 100mm stem, now im currently using a 110mm stem with 0.5cm spacers and 4.5mm top cap. saddle to handlebar drop is 13cm
andylav
by andylav
Beautiful looking build.
Keen to hear your views on how it rides.
syplam
by syplam
Nice bike. Which B.B. did u install? I’m thinking what I should get for my f10
