SRM Look Exakt Pedals
moyboy
by moyboy
I've owned a set of the Exakt pedals when they first became available to order, and have since returned them as the installation with the tool and charging.
What you get for the price wasn't in worth it in my mind, as the Vector 3's i was using was about $800 cdn cheaper and you get cycling dynamics etc...
I have gone back to the Vector 3's after the design change with the battery doors and i no longer get wattage spikes and missing right hand pedal notifications.
Ringo
by Ringo
moyboy wrote:
Thu Sep 13, 2018 4:30 pm
What about the charging and installation? They both seem easy and straightforward.
Please be more specific..
As for the vectors, there are a lot of people saying that even with the new doors problems remain. I think the problem is due to the type of battery
fogman
by fogman
What is the weight difference between a pair of SRM/Look Exakt pedals and a pair of Look Kéo Blade Ti pedals?
It's all downhill from here, except for the uphills.
TobinHatesYou
by TobinHatesYou
fogman wrote:
Fri Sep 14, 2018 3:54 am
Difference of ~120 grams for the pair. Assiomas are 5g lighter than Exakts per pair.
In general, pedal PMs are the best “weenie” option for full-power measurement, they are significantly lighter than the combination of spindle PMs and modular cranks that support them.
RyanH
by RyanH
Barely, and at a significant higher price
SISL2 SRM without rings: 460g
Speedplay Ti: 145g
Total: 605g (actual, not mfg claimed)
THM Clavicula SE: 290g
SRM Exakt: 310g
Total: 600g
TobinHatesYou
by TobinHatesYou
Assiomas are 5g lighter than Exakts and then there’s also the weight difference in the cleats. The Assioma/Clavicula is still more expensive, but definitely lighter.
Ringo
by Ringo
Wrong info. Please delete.
mrlobber
by mrlobber
RyanH wrote:
Fri Sep 14, 2018 6:03 am
Speedplay Ti: 145g
SRM Exakt: 310g
Total: 600g
Not really. First, you need to get a frame which fits BB30 crank ;) :D
And for SRM price + SISL crank, you still can buy Clavicula + pedal PM easily, the first combination is ~2500 EUR in Europe, the 2nd - 1150 EUR plus pedal PM (Vectors & Favero are both under 1000 EUR). If you've got cranks already, then it's cheaper, though.
Plus, the difference in weight for cleats, as Tobin mentioned (both for Speedplay as well as Time, if you choose Xpresso15)
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
maquisard
by maquisard
DCRainmaker's review has just been posted - pretty much agrees with your view point.
https://www.dcrainmaker.com/2018/12/srm ... eview.html
SRM once again producing a product that is years behind the competition at a premium price.
Monkeyfudger
by Monkeyfudger
Lolz, that’s a shit review really ain’t it. I wouldn’t buy ‘em if they were half the price, I couldn’t be bothered with the install procedure and only supplying one charging pod thing is taking the piss.
moyboy
by moyboy
Yes it was an entertaining read. Especially with the charging cable and installation points. They do offer to sell you another cable but why at that price.
maquisard wrote:
Tue Dec 11, 2018 11:05 pm
TobinHatesYou
by TobinHatesYou
I have been happy with both my Vector 3s and Assioma Duos for different reasons.
Vector 3s for true KeO compatibility, zero dropouts, Cycling Dynamics.
Assiomas for price, instant angular velocity, rechargeable batteries.
The Assiomas get knocked down slightly because I do experience instant/short dropouts a few times on a 40 mile ride and the KeO cleat compatibility isn't quite 100%. Disregarding price, I'd go with the Vectors...those occasional dropouts I'm experiencing on the Assiomas are mildly annoying.
petromyzon
by petromyzon
Amidst all of the criticism of the pedals I hadn't really noticed that SRM don't have active temperature compensation in the cranks yet!
Hilarious company - this is what happens when you have an idea and design so good that it defines an industry and revolutionises sports science, then sit on your laurels for 25+ years.
Added to which, WTF are Look doing? This is their second powermeter product that is basically DOA.
TobinHatesYou
by TobinHatesYou
It’s pretty clear that Look doesn’t have the in-house technical know-how to do it themselves, so they partnered with Polar and SRM for each project. Not surprising in the least...building a power meter that is consistent across thousands of units manufactured is actually quite hard.
maquisard
by maquisard
petromyzon wrote:
Wed Dec 12, 2018 9:09 am
I have said this before, the SRM design is beyond dated now. The competitors, Power2Max, Quarq, Stages, Infocrank... everyone else are doing active temperature compensation now that basically maps temperature to any offset requirement. This is also a multi-point map and so can account for any non-linearities in either the strain gauge or the materials on which the strain gauge is mounted (important in case of carbon cranks).
