Look 795 Blade
bearapy
by bearapy
Frame finally arrived.
A few problems already. Frame does not have enough clearance for the pioneer power meter on drive side.
Seat post clamp bolt came siezed up. :roll:
jlok
by jlok
My friends wanna buy this frame with Stage dual side PM. Is it DS or NDS that doesn't clear the PM sensor? any picture?
bearapy
by bearapy
jlok wrote:
Thu May 02, 2019 7:00 am
No problem on the non drive side but there is a boxy bit at the bottom which causes clearance issue. Hope this helps.
Applesoap
by Applesoap
bearapy wrote:
Thu May 02, 2019 1:15 pm
What bottom bracket are you using? I'm using a cheap rotor one which I want to replace asap.
bearapy
by bearapy
Applesoap wrote:
Tue May 14, 2019 12:09 pm
Hambini. Fixed a creaky BB on my last bike with hambini so this seemed like a safe bet. Token is the recommended look bb but read it uses undersized bearings so servicing bearings may become an issue later.
asiantrick
by asiantrick
anyone knows whats the max tires clearance for this frame?
Applesoap
by Applesoap
asiantrick wrote:
Tue May 14, 2019 4:32 pm
28mm for rim and 30mm for disc.
Applesoap
by Applesoap
bearapy wrote:
Tue May 14, 2019 1:55 pm
I had a feeling you were using Hambini, how difficult are they to install?
bearapy
by bearapy
Applesoap wrote:
Tue May 14, 2019 9:47 pm
Not difficult at all. I used a cheap bb pressfit tool without any issues. You can also DIY a tool with a threaded rod and a pair of nuts with the included press adapters.
brearley
by brearley
has anybody built one of these yet?
i'm looking at one for my 2020 bike running dura ace 9120 hydro mechanical.
CAAD8FRED
by CAAD8FRED
This bike is heavy! I asked for the weight of the disc brake frame size 54 and fork individually.
Applesoap
by Applesoap
brearley wrote:
Mon Jun 03, 2019 8:04 pm
My look 795 is running Dura Ace 9120, not too difficult to install. You will need to buy longer shift cable housings because the default in box ones are too short. In terms of ride quality, it feels very very stable like it's stuck on rails and is also surprisingly quite plush.
rudye9mr
by rudye9mr
^ what was your last bike and was the geometry hard / easy to dial in for the LOOK vs previous bicycle?
bearapy
by bearapy
Not light indeed. Size M and current build is 8.8kg :noidea:
Can bring it down to 8.2kg if I use a smaller cassette and climbing wheels with latex.
jlok
by jlok
thx for the heads up. Looks great!
Any first ride impression?
p.s. looks like it's Hong Kong?
