Look 795 Blade
Pew
by Pew
It's getting built! Still need to figure out some di2 wiring and cut the steerer.
Is there supposed to be some kind of di2 battery holder? There were only two o-rings with my frameset. I just put the battery inside the seattube (with those o-rings) and fastened it with a zip-tie. Seems to work :noidea:
And yes, there was a Garmin holder inside the package. Somehow I managed to miss it :roll:
bearapy
by bearapy
Pew wrote:
Sat Jul 02, 2022 6:08 pm
That is the factory way to mount the di2 battery. If it isn't moving or making noise then it'll be ok
Leon
by Leon
You mean in the seat post right? Not seat tube?
Superb bike btw.
Ride bikes, not tanks!
Leon
by Leon
And a pic of yesterday. The purple color is just amazing.
iankovski
by iankovski
Guys, I want to have your opinion here. Couple months ago, I bought a used 795 Blade RS here in Germany. Probably I was not that careful inspecting the bike (also didn't bring it to a bike shop to have a deep look). It has a SRAM Red crank with Quarq DZero Dub PM and an Absolute Black Oval chainrings.
I just realized that something doesn't look great in my BB-crank integration. For me, it looks like there is a piece missing in the BB-crank section because the free space in between is just too small. So even if I got something like a small rock in that place it'll badly damage the frame.
I want to show you some pics because it looks to me that the chainring/PM is rubbing the frame and I'm a little concerned if it's damaging the carbon in the frame or only the paint. Also if it looks like not right, if it's the point to talk to the seller and try to arrange something for this.
P.S.: don't mind the frame damage due to a chain drop that I didn't notice.
JimV
by JimV
I just looked at mine. 795 RS with RED AXS 46-33. The space looks similar. Take the chain off to the outside and either have some help or tie it up to the FT deraileur so it is out of the way and see if the crank spins freely.
iankovski
by iankovski
JimV wrote:
Tue Jul 12, 2022 5:44 pm
Could you please upload some photos? Yes, the crank no spins freely, I already put 700km on it. My concern is that you can see the white paint on the outside of the smaller chainring. Did you notice that?
Leon
by Leon
I have no experience with SRAM but it sure looks tight..... Did you look online for exploded diagrams of the crank build up? On myDale for example there are very nice diagrams which tell you how many spacers should go in etc.
Have not checked my Blade with Campagnolo BTW. So I even don't know but maybe it is just as tight. I will have a look when I get home.
bearapy
by bearapy
iankovski wrote:
Tue Jul 12, 2022 12:50 pm
Also interested to know because I have the same issue with this. I don't get enough clearance to use a right side power meter as it catchs and rub.
Suspect it is 386EVO compatibility issue
iankovski
by iankovski
Leon wrote:
Wed Jul 13, 2022 6:52 am
I just checked the SRAM manual, will share it later here. Which website is this, could you share it here?
bearapy wrote:
Wed Jul 13, 2022 11:04 am
Probably it's if you don't use spacers enough. But the BB for the 795 is only 386, right? Not the EVO.
bearapy
by bearapy
iankovski wrote:
Wed Jul 13, 2022 6:59 pm
I had the pioneer dura ace power meter, shimano cranks don't have spacers. I tried adding spacer (1.5mm iirc before it let me spin freely) but then I can't shift the front derailleur (limit screw already removed :noidea:)
Leon
by Leon
Oh, I meant the Cannondale website and cannondale cranks. So nothing related to SRAM and Look.
rudye9mr
by rudye9mr
For reference..campy 12 50/34 on token BB.
@RDY on seatpost 3 from 2...any difference in comfort given #2 has an elastomer that supposed to help with comfort?
Leon
by Leon
That's the same as mine. Although I use the Campa BB386. And that has an edge on the cup for the clamp to secure the crank.
Luften
by Luften
rudye9mr wrote:
Thu Jul 14, 2022 12:37 pm
Huge cracks running up your BB and seat post, have you had them checked out?
