If you look at the manual, the 30mm tool is correct. The bb uses spacers to fit 24mm axle so presumably you install using the 30mm tool before fitting the spacers.tomyboy123 wrote: ↑Mon Jul 01, 2019 3:27 pmThanks. Will try this on the next attempt, with no plastic spacer. I guess that might do the trick as Pro also don't use any spacers.
Any thoughts regarding which is the right model, if I would like to use the tool with a shaft, to remove the bottom bracket?
Still dont understand, if Blade is using TF38624, how will tool with 30mm shaft fit?
https://www.merlincycles.com/token-ninj ... 26617.html
30mm
24mm
https://www.tokenproducts.com/images/BB ... 190212.pdf
