Izalco Max Rim Tire clearance
halcyongolf
by halcyongolf
I'm looking to buy an Izalco Max frame to build up. For those with experience with this bike, what is the largest tire (tyre) you can fit? Will it clear a 28mm tire on wider (25mm+ rims) or is 25mm about the best I can hope for? Thanks.
scale29
by scale29
My wife has an Izalco Max disc, not sure if this differs from the non disc much in regard to tyre clearance, I can fit a Roval CLX32 with a 28mm Sworks 2Bliss tyre in the frame but I'd not want to ride it far, I stick to 26mm max for this bike.
emotive
by emotive
I don't know anyone on the Izalco Max rim version, but I do have 4 friends riding the Izalco Max Disc version, some with 28 tyres. Even on the disc version 28mm tyres are a "sometimes"
One friend has 28mm Conti GP4000II on DT Swiss RC38 Spline wheels. They are only 21mm wide rims, and the 28mm tyres fit. Another friend has a 2017 model Izalco Max Disc with wider Focus Concept DB (rebranded Fulcrum wheels) and the GP4000II in 28mm did NOT fit in the fork, but did fit in the chain stays, so he is running 25 on the front, and 28 on the rear.
I would expect the stock wheels are 23mm outer, 17C inner. GP4000 will measure 30.2mm on a 17C rim when new, and gain 1mm width over the first 100km of use. are large tyres than Vittoria and Schwalbe, so you MAY fit those on a 17C inner width rim.
halcyongolf
by halcyongolf
Thanks for the info everyone. That helped quite a bit.
sib
by sib
I'm running 25mm Panaracers on Fulcrum Racing 5 LGs. which come out to about 27mm wide actual. I wouldn't want to run anything bigger on the front, but the rear has a little more clearance.
sawyer
by sawyer
I have the rim braked version, with Campagnolo skeleton brakes. Running 24.2mm external rims, I 25 GP4000S2 fits with a few mm to spare. Honestly a 28mm might fit, but at best it would be too close for comfort, and certainly in anything wet would pick up tons of leaves, rub them against underside of calipers etc.
tk2306
by tk2306
I have a Izalco Max rim brake frame. I have run various 28mm measured tyres with no issues whatsoever. Would have comfortably ridden 20,000km with this setup.
Love the frame.
sawyer
by sawyer
tk2306 wrote:
Tue Jul 17, 2018 6:37 pm
Love the frame.
Hi - that is interesting. Can I ask what calipers you're using, whether you've used 28mm GP4000S2 nominal, and what the clearance is like on the specific tyres/calipers you've been using?
MediumSizedMonster
by MediumSizedMonster
Have 2015 Izalco Team SL (I think predecessor, rim brakes obviously). Run 28mm no problem, full Record group.
tk2306
by tk2306
sawyer wrote:
Wed Jul 18, 2018 3:14 pm
Love the frame.
Sorry for the slow reply, I have just gotten back from a holiday.
I am using DA 9000 calipers.
I have used 25mm Veloflex Masters on HED+ rims (these meaured 28mm bang on), 25mm GP4000 on HED+ (again 28mm measured), 28mm Clement LGG, Vittoria Corsa Graphene 28mm.
All of them without any rub front or rear. Clearance has not been an issue. I wouldn't go bigger than a measured 28mm however. I think a 28mm GP4000 on a wide rim would not work.
The frame is a 56 FWIW.
iamalex
by iamalex
Any more experiences with folks running wide rims and the Izalco Max Disc?
I’ve got a 58cm Izalco Disc and 28mm tyres on 17mm internal width rims is not a problem.
Looking at buying some 21mm internal width rim wheels to run 25/28mm tyres and wondering if they’ll fit?
doogie2304
by doogie2304
I’m on a 2015 izalco max with campy record brakes and campy boras with 25mm conti gp4000s2. I think that 28mm might be a problem. Yesterday, part of a 30km climb we rode had melting tarmac and small gravel chips. The gravel chips would stick to the tyre and then get wedged between the tyre and the brake calipers - this went on for about 15km - not fun!
kofsw4
by kofsw4
iamalex wrote:Any more experiences with folks running wide rims and the Izalco Max Disc?
I've got 28c Specialized S Works 2bliss on 21mm internal Light Bicycle rims on my izalco max disc. They measure just over 29mm and I would not go any wider than that.
I've also tried 25c GP4000s and Michelin Power competition on these rims. Both measured 28mm exactly and fitted fine.
28c GP4000s on a 20mm Roval rim measured 31mm and were too wide, rubbing on the front fork and rear stays.
Hope that helps
iamalex
by iamalex
Thanks for the advice, sounds positive about clearance. Now I need to choose between 35 and 45mm deep rims...
scale29
by scale29
28mm SWorks 2bliss on Roval CLX32 don’t fit on my wife’s Max disc on the front.
She runs LB36 with One Pro tubeless 25mm.
