WW alternative for Pro Stealth saddle (152mm width)
refthimos
by refthimos
With my SystemSix on order, I'm looking to turn my Evo Hi-Mod into a WW build. I run the Shimano Pro Stealth saddle in the 152mm width. Anyone else out there who runs this saddle have suggestions for appropriate WW (e.g. all-carbon) alternatives?
EVO | 5.37kg
SystemSix | On order
TCR Advanced SL Disc | 7.35kg
P5 | 9070 Di2 | SISL2 SRM | Enve 7.8 | Alto Disc
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
swright
by swright
I have a Fabric ALM Ultimate Shallow (155g) that is nice, albeit a bit pricey. When you hold and feel it, the padding seems light, but I've never had any problems as long as the bibs/shorts have a good, quality chamois.
I also have a Fabric Scoop Shallow that is a bit more padded (and heavier) that I use for really long rides. The Fabric saddles are shaped similarly, so having different saddles from the same manufacturer makes swapping and (re-)fitting a snap.
I really like the Fabric saddles (https://fabric.cc/products/saddles/) and they have a pretty good range of sizes, shapes, rail materials, colors and weights.
cheers,
Scott
p.s. I asked a comparable question a while back, have a look at this thread: https://weightweenies.starbike.com/foru ... 3&t=150809. Have a look also at the Pro Stealth Carbon (~175g), Fizik Aliante R1 (175g) and the Bontrager Montrose Pro (~167g) which is very competitively priced.
nex
by nex
I have a Berk Lupina in 132mm and it is the most comfortable saddle I've owned. He also makes them in 150mm.
refthimos
by refthimos
swright wrote:
Thu Jul 12, 2018 8:16 pm
Yes, the Stealth Carbon is my workhorse saddle on all my bikes other than the TT bike. Looking for a true WW alternative (i.e. under 100g) for a special build.
Berk Lupina sounds like a strong contender, but with a saddle it's all about the shape, right? From the photos I can find, it does appear to have a similar shape (cutout, scooped in middle rather than flat, sitbone area angles down) but is there anyone out there who rides/had ridden both saddles and can comment if they indeed fit similarly?
EVO | 5.37kg
cycleboyco
by cycleboyco
Take a look at this thread, page 7 if the link does not already take you there:
https://weightweenies.starbike.com/foru ... 0&start=90
Person was on a Pro Stealth and is moving to the new Berk Dila-about 100 grams, but you can get it lighter if you forego the padding. No comments from him yet on his ride experience on the Dila, but he does show pictures of both saddles and they look similar. Dila is 160mm at widest point. I am considering this saddle to replace a Specialized Power. I would keep an eye on this thread for comparison comments or PM him.
wingguy
by wingguy
That Dila certainly looks the part.
Several of the other saddles mentioned are good saddles and may work for you, but none of them are remotely similar to a Stealth. Hardly anything is, tbh, so if you want to sick with a similar shape but drop a measurable amount of weight the Dila is going to be one of, if not the, only options.
refthimos
by refthimos
cycleboyco wrote:
Thu Jul 12, 2018 10:14 pm
Yes! This is a great lead and certainly looks like the best prospect I've seen so far. Much thanks!
EVO | 5.37kg
