joejack951
by joejack951 on Thu Jul 12, 2018 1:39 am
JScycle wrote: ↑Thu Jul 12, 2018 12:31 am
LeMomo wrote: ↑Wed Jul 11, 2018 9:02 pm
Sadly the spacing trick doesn’t work with centrelock rotors!
I can't remember where but I saw some centrelock microspacers
November Cycles.
I posted the following in another thread on the same topic:
Diameter over the centerlock splines is 35.5mm and the rotor to hub mating surface is right around 40mm on my Icetech rotors. If you can get it over the splines, a 40mm OD by 34mm ID shim would stay nice and concentric based on my hubs' dimensions
Since you are in the US, check out
www.mcmaster.com, they sell a 45mm OD x 35mm ID shim which ought to work. They have 0.1mm to 1mm thick options.
jlok
by jlok on Thu Jul 12, 2018 3:29 am
I filed the 6-bolt to centerlock adaptor a bit to fit. Maybe it works with centerlock rotor as well.
SilentDrone
by SilentDrone on Thu Jul 12, 2018 3:46 am
kdawg wrote:....I find if I remove my wheel to put it in the car or something I have to fiddle about to get rid of some minor rub.
This! But I can’t for the life of me understand why this is the case. It doesn’t happen when I remove the skew to load my mtb with xtr brakes into my car. But my dura ace 9120 it seems to move ever so slightly. Weird.
kafreeman
by kafreeman on Thu Jul 12, 2018 4:38 am
joejack951 wrote:
November Cycles.
I have a set of 2014 Reynolds Assaults I got at firesale price last year. I had to hit the inside of the shim from McMaster with a dremel to get them over the centerlock splines.
Sent from my SM-G965U using Tapatalk
GlacialPace
by GlacialPace on Tue Jul 31, 2018 11:01 am
Another possible problem is worn discs that are thinner, this can cause issues with multiple wheelsets. Not sure about road discs but Shimano MTB ice tech rotors wear out pretty fast (can be done in a season if you ride steep stuff a lot) I imagine road discs are simillar though maybe don't get the same level of abuse so may last a bit longer.
RichTheRoadie
- Tinker, Taylor, Tart
by RichTheRoadie on Tue Jul 31, 2018 11:24 am
SilentDrone wrote: ↑Thu Jul 12, 2018 3:46 am
Tightness of the thru-axle would be my guess - minor changes make a big difference.
Grab your TA and tighten or loosen it by a fraction of a turn - I bet you get rubbing?
RyanH
- Moderator
by RyanH on Wed Aug 01, 2018 4:08 am
Yeah, as mentioned, consistently torquing the thru axle to the same spec helps alleviate the issue. It doesn't have to be exact but I noticed if I don't torque it down enough it will rub.
LeDuke
by LeDuke on Wed Aug 01, 2018 7:55 pm
RyanH wrote:Yeah, as mentioned, consistently torquing the thru axle to the same spec helps alleviate the issue. It doesn't have to be exact but I noticed if I don't torque it down enough it will rub.
A small dot of paint or a slight file mark on the TA help. As in, dot at 6 o’clock = properly tightened.
spdntrxi
by spdntrxi on Wed Aug 01, 2018 8:27 pm
LeDuke wrote: ↑Wed Aug 01, 2018 7:55 pm
like that ideal.. will use it
TonyM
by TonyM on Wed Aug 01, 2018 8:29 pm
Great tip!
Will do it on my bikes!
LeDuke
by LeDuke on Wed Aug 01, 2018 11:39 pm
TonyM wrote:BTW how do you torque the rear TA to the correct N.m value? (mine has a lever attached and I can't use a torque ratchet)
Not sure. I use bolt-on TAs.
Half the weight of most lever operated TAs.
