PInarello F10 disk - weight vs Tarmac SL6
sychen
by sychen
Mark, it sounds like you need to get used to your new bike and position.
If your setup have changed quite alot, then your body needs to get used to it to get the most out of a more aggressive position.
For the "snap" you are looking for, a wheel change might be the ticket.
Those Mavic's are quite heavy and while good for holding speed, not going to climb too well.
As others have said, a set of Bora Ones would give the bike a very different ride.
For reference weight of my entire wheelset : Roval CLX50/Turbo 26mm/DuraAce Rotors/buytl innertubes/Spec thruaxle
Rear: 1468g
Front: 1144g
maybe weigh your wheelset as a whole to see what rotating weight you are dealing with.
guyc
by guyc
Lose 1kg from your body
MarkPW
by MarkPW
I was looking at the CLX50 having seen them in the flesh, on the Tarmac SL6. Only reason I went with the Mavic is my Kysrium have been bulletproof.
My wheelset:
Rear: 1484g (inc xg-1190 cassette and RT900 160mm rotor) + 66g thru axle = 1550g
Front: 1179g (inc same rotor) + 29g thru axle = 1208g
There is clearly a few hundred grams to lose all over, but working with the F10 seems hard to justify when the SL6 is £1k cheaper and lighter. I desperately want to love the F10, but while the option is there I can get rid and not lose out financially.
Lost 5kg this year, but lost a lot of power with it and it's not easy to get back!
TonyM
by TonyM
Watch out to loose fat (not water, muscle etc....)!
TonyM
by TonyM
MarkPW wrote:I was looking at the CLX50 having seen them in the flesh, on the Tarmac SL6. Only reason I went with the Mavic is my Kysrium have been bulletproof.
My wheelset:
Go tubulars, then you will have light wheels.
But at the end a Tarmac disc or Emonda SLR disc will be much lighter than the F10 disk.
alexneumuller
by alexneumuller
My Tarmac is 6.9kg
CLX50 Wheels
Ax Lightness Handlebar
AX Lightness Saddle
Enve Aero stem
THM M3 Crankset
Sram Red Etap
Speedplay Steel Pedals
Arundal Bottlecages
MarkPW wrote:New here! I've built up a Pinarello F10 disk and it's come out at ~7.8kg, it's a lovely bike but I was expecting it to be closer to 7kg. It has 1k MOST Aero bar, SRAM red hrd wifli groupset and chainset, Mavic Cosmic SL UST wheels (1570g pair without tyres), Dura-ace 160mm rotors, Dura-ace R9100 carbon pedals, 230g Prologo saddle. There is probably 200g to lose with lighter wheels, but I can't see where else I could make any significant reduction.
I'm wondering whether I should swap it for the S-works Tarmac SL6 disc frame as I'm seeing builds under 7kg. Does anyone know how these two frames compare? The F10 is aero and as expected, great on the flats, but I had hoped for the best of both worlds with living in a very hilly area.
Any advice would be appreciated!
IF Crown Jewel TI
IF Crown Jewel Steel
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5d
English Cycles 10th Anniv Edition
Cannondale SS Evo Disc
TonyM
by TonyM
alexneumuller wrote:My Tarmac is 6.9kg
CLX50 Wheels
AX Lightness Saddle
Enve Aero stem
THM M3 Crankset
Sram Red Etap
Arundal Bottlecages
Tarmac rim or disc brake version?
alexneumuller
by alexneumuller
CLX50 Wheels
AX Lightness Saddle
Enve Aero stem
THM M3 Crankset
Sram Red Etap
Arundal Bottlecages
Still needs final fitting
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5d
TonyM
by TonyM
Wow long legs short torso!
sychen
by sychen
Can't be much seatpost in the bike.. I'm assuming saddle height needs adjusting?
alexneumuller
by alexneumuller
Still needs adjustment, but not much. Got long legs. And still within allowance of seat post max out.
sychen wrote:Can't be much seatpost in the bike.. I'm assuming saddle height needs adjusting?
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5d
guyc
by guyc
That saddle is incredibly forward Alex - that must be stressing the rails.
alexneumuller
by alexneumuller
It is at its max forward. Need an inline seatpost.
guyc wrote:
Thu Jul 12, 2018 9:08 am
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5d
alexneumuller
by alexneumuller
guyc wrote:That saddle is incredibly forward Alex - that must be stressing the rails.
Have ordered one!
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5d
eforce123
by eforce123
hannawald wrote:
Wed Jul 11, 2018 9:19 am
if not sure about time xpresso (they work well and as a bonus you will not mix sram etap with shimano pedals:) you can buy chinese version on aliexpress called Costelo for some 60 usd. people use it with success here..
for integrated stem-bar look at ursus magnus. light and italian, comes with aero spacers so looks pretty integrated. so many options to make it light and functional.. no need to regret, you have one of the best frames available.
I am not finding the Costelo pedals on aliexpress???
