THM combo Ceramicspeed
KaneChang
by KaneChang
Hello everyone, I got a THM Clavicula SE & want to combo with Ceramicspeed 4130 bottom bracket, but like this case I need to add spacer to bottom bracket? because Ceramicspeed 4130 have many spacer in the package... :|
But follow the THM install instruction book only need to add original 1 & 2mm space to cone sleeve side/Axle side, but I think this is using THM 4130 bottom bracket.
So if anyone used this combo please give me some suggestion, many thanks.
:beerchug:
UpFromOne
by UpFromOne
Just shim the right arm as needed to equalize the distance of each crank arm from the chainstays.
Unless you have a unique chainline requirement, then shim it for that priority.
