wingguy wrote: ↑Wed Jul 11, 2018 12:06 am
themidge wrote: ↑Tue Jul 10, 2018 11:21 pm
Just using the front derailleur to dump gears before a traffic light ("Or sharp corners. Or whatever") is less shifting than shifting several sprockets at the back. You could use the rear derailleur if you want, but I certainly don't if the situation means that the front is easier.
When you are then re-accelerating back up to speed, when is one big shift on the front mech ever better than running a couple of shifts through the cassette?
When the gear I was in to start with wasn't so difficult I can't get straight back on top of it with a little effort (that effort will also get me further towards my original speed after the initial acceleration aided by the easy gear provided by the little ring).
Of course, in other situations like turning a corner into a very steep climb, I only shift down into the little ring and leave it there for the duration of the climb.
Look, in all these scenarios,
it depends, sometimes you don't need that much of an easier gear, so you just use the back.
wingguy wrote:Look, my current front shifting setup is close to flawless, but for reliability of shift and for cadence management I will take rear shifts under load over a front shift under load any day of the week.
Front shifts shouldn't ever happen under load, so I suppose I'd lose a bit of time by easing off, but I'll take that for being closer to the right gear with one sweep of the shifter. On a well set up mechanical FD, an up-shift isn't that much of a big deal.
wingguy wrote:themidge wrote:It is on my shimano set up, one click at the front vs 4 or 5 or 6 at the rear.
Six? What ratios?
Okay, 6 is a bit much on my 10 speed setup, but it sounds about right to me for Rotor's new 13 speed or Campy 12, that's only half the range of the cassette, not dissimilar to the difference between chainrings. I'm only guessing there though, I have no experience of those systems.
wingguy wrote:themidge wrote:Let's say I reach the top of a climb in the little ring and the middle of the cassette, now for the false flat at the top of the hill I change to the big ring and change to a one harder sprocket at the back.
Why would we say that? That's a gigantic cadence change and it's not something any sane rider would be doing
I just went outside in my socks to try it (on a flat road) and it certainly is a big change in cadence, but given the change of gradient in my 'scenario', I don't think it's too big, nor insane to do. I don't know about you, but I don't feel that I have to keep my cadence the same, or even within a fairly tight range, all the time.
wingguy wrote:themidge wrote:That's 2 clicks that I can do at the same time, compared to at least 4 at the back for the same effect on 1x.
But assuming mechanical, one of those 2 clicks is actually a sweep that is much more difficult to do while going full gas than the other clicks. Assuming electronic, your way uses 2 seperate clicks vs one longer click. Either system, your suggestion takes more effort and coordination.
Who said anything about full gas? In the little ring and the middle of the cassette isn't a gear I'd be in going full gas at the top of a climb. To talk about sweeps and clicks kind of cancels out IMO, to do the opposite (big to small and one easier gear at the back) would require a long sweep of the rear on 1x. Again, 2x is not better because of it's chainrings, but because of all the other advantages it has. I concede that 1x is easier to change gear on the whole, but I also maintain that I find it easier to dump gears using the chainrings than using the cassette.
