Allez sprint disc
Helmetbox
by Helmetbox
blehargh wrote:
Wed Jun 19, 2019 2:27 am
Can you post another photo? Curious about how the bottom bracket area cable routing works. The link doesn’t work for me. Thanks!
Here you go Image
https://ibb.co/5Gjd1Ph
by Nefarious86
Fresh C38s for daily duties. Image
Sent from my SM-G977B using Tapatalk
Using Tapatalk
Helmetbox
by Helmetbox
Nefarious86 wrote:
Wed Jun 19, 2019 10:40 am
Nice. Did you cover your bb area to prevent water from going in to your junction b?
blehargh
by blehargh
Helmetbox wrote:
Wed Jun 19, 2019 6:30 am
Here you go Image
Cool. Assume you need to remove the bottom bracket and stuff the junction box inside the down tube.
Helmetbox
by Helmetbox
blehargh wrote:
Wed Jun 19, 2019 3:06 pm
Here you go Image
Nope, you don't have to remove the bb. For tarmac and venge vias, there is actually a cover to prevent water from splashing on. If you take a look at your allez disc, you will see the exact same hole. Just wondering how to cover it. Looks like I just have to use electrical tape to cover the left hole.
Hexsense
by Hexsense
Helmetbox wrote:
Tue Jun 18, 2019 11:13 pm
Hexsense wrote:
Tue Jun 18, 2019 1:32 pm
Helmetbox wrote:
Tue Jun 18, 2019 11:42 am
Nobody uses di2 for disc allez?
Are you blind?
Go back one page, my bike and many others are set up with di2 :roll:
I am asking how do they cover the bottom bracket area to prevent water from reaching the junction b, but seem that nobody reply.
I do not answer because i don't cover it. So i wait and see if anyone bother to cover that hole. I didn't see the need to, but seeing how you route i now should answer because i see that it matter to you but not on my set-up.
Both my Di2 cable and junction b go over the top of the bb itself, not underneath. Use bottom bracket that encapsulate things left to right (not just simple two bearings that leave spindle expose in the center). Example of this type of bb
I route every cable from everywhere to one side of bb hole first, then join them together with junction b in the seat tube on top of where bottom bracket casing will be inserted. Then insert the bb and viola, di2 stuff rest on top of bb and spindle hide inside the shell away from dirt.
Bottom hole is as exposed as regular cable groupset.
by Nefarious86
I left mine open no issues
Using Tapatalk
Schadenfreude
by Schadenfreude
You could use some sort of clear cable frame protector sticker to cover it up? I used a small circle piece to cover the hole left when I remove the cables for a front derailleur after upgrading with di2.
Also, I love that "Splash" pattern frameset.
Helmetbox
by Helmetbox
Hexsense wrote:
Wed Jun 19, 2019 3:51 pm
Are you blind?
I see. Does the placing the junction b on top the bb cause more rattling? The way I route is following a tarmac routing. :)
riochang
by riochang
Sharing my new bike: 2019 Allez Sprint Disc Artist Edition
Really really like the new paint job.
Total weight 7.38kg
build list attached!
jfranci3
by jfranci3
Looks great.
ToughInTheStreets
by ToughInTheStreets
Very sharp! Nice build. Interesting choice in pedals.
Sent from my SM-G960U1 using Tapatalk
willembad
by willembad
Great bike! Is the white matte or gloss on that frame?
Sent from my SM-G950U using Tapatalk
riochang
by riochang
willembad wrote:
Thu Jul 04, 2019 4:27 pm
It's matte white and gloss black.
There's one benefit with matte white, the welds are much less obvious :lol:
ToughInTheStreets wrote:
Thu Jul 04, 2019 4:12 pm
Casual mode right now, would be swapping to clipless soon
CrankAddictsRich
by CrankAddictsRich
riochang wrote:
Thu Jul 04, 2019 3:46 pm
Total weight 7.38kg
IMG_8055 2.jpegIMG_8057.jpegIMG_8058.jpegScreenshot 2019-07-04 at 22.43.03.png
That's the VHS Artist edtion inspired by the graphics of 80's and 9o's VHS tapes. my LBS has one and it is a great looking bike.
