Allez sprint disc
wolfesquire
by wolfesquire
So I do not ride in wet weather and it is extremely flat here (75km ride you may hit 125m of elevation) so is it worth moving from a rim brake allez sprint to an allez sprint disc? Several people in the area are moving to disc brakes, but I can't tell if it is due to "better" or because its the "new thing".
Sock3t
by Sock3t
If you want to spend money, sure, do it.
If you're happy with what you have, I wouldn't bother.
ancker
by ancker
wolfesquire wrote:
Fri May 10, 2019 5:33 pm
The disc brake package is all-around stiffer than the rim brake package.
And better stopping power isn't just for descents....
Helmetbox
by Helmetbox
https://ibb.co/SvBxmkL
In progress, sold off my rim verison building the disc verison
07stuntin6r
by 07stuntin6r
Helmetbox wrote:https://ibb.co/SvBxmkL
The Sagan scheme looks so much better in person. Seen the new tarmac and I almost lost it
rainerhq
by rainerhq
Lots of talk here about adapters in BB30 bearings will creak. Is this specific to Specialized or what?
I have a 2nd Jamis Renegade. It has BB386 and Wheel MFG adapters to use Shimano crank. Never heard a creak.
I understand the Allez frame will come with BB30 bearings.
Two options for Shimano crank: 1) the easier/cheaper. Use these adapters, but eventually will creak. https://r2-bike.com/WHEELS-MFG-Innenlag ... owtech-48g
2) Use Praxis Works BB and have better chance to avoid creaking. https://r2-bike.com/PRAXIS-WORKS-bottom ... road-crank
Domane
Speed Concept
"Nothing compares to the simple pleasure of a bike ride"
Helmetbox
by Helmetbox
rainerhq wrote:
Mon May 13, 2019 9:16 am
Been using wheel mfg adapter on my specialized bikes, no issues at all. My old rim allez also installed with the adapter, no issues.
Sock3t
by Sock3t
Mate you down under?
Schadenfreude
by Schadenfreude
@Kesselflicker - how is the rear derailleur di2 cable routed? It looks like it is fixed externally to the frame? Has it been wrapped with anything to strengthen it?
rainerhq
by rainerhq
Is this seatpost with 0 setback? Bought separately?
Domane
Speed Concept
Kesselflicker
by Kesselflicker
Hi,
Rear Di2 cable fixed with a cable tie.
Yes, seatpost with zero offset. Bought from Specialized, but temporary sold out.
Hexsense
by Hexsense
Di2 cable exit the chainstay at about 5cm in front of rear derailleur mount.
There is also a rubber plug to make it look nicer but I lost it.
FD di2 cable with rubber plug
Quick and dirty snap of my di2 build (size 49) for reference. I Probably should have routed every cable to the left side instead of left cable cross to right (and right shifter to front brake).
ancker
by ancker
Kesselflicker wrote:
Tue May 14, 2019 8:41 am
Hi,
Link or part number on seatpost?
rainerhq
by rainerhq
You can find a copy from ebay. 5mm setback though.
Domane
Speed Concept
