2019 bike roll out jam
Where does this come from?DartanianX wrote: ↑Sat Sep 29, 2018 12:15 pmSo... S5D fit options.
All regular lengths and two (maybe more) angles, when they are slammed - one replicates the current S5 with a -6 stem and another which will replicate a -17 stem.
Also, I'd go for -17 probably just because of looks alone
From a dealer I know who has one built, ready to ride / have on the floor when they go live.
Does the dealer know if the bike / frameset can be ordered with ANY choice of stem or they come with predefined lengths?
I've seen the geometry chart, but there was no mention of size predefined stems.
will surely need the stem/bar reach stack comparison to the old S5 instead of frame reach stack figures.
As I have written on another post,the easiest way would be to include a min /max(min=no spacers,max=2/3 1cm spacers)fork dropouts to upper surface of the handlebar(not lower because it does not seem to be round ).Then you can take into account the bb drop and you can be quite accurate on the frame size/stem angle you need.Of course this should be calculated with the most common stem length according to frame size(e.g.54/11 cm stem,56/12 cm etc).This applies to all manufacturers using dedicated stems(Cannondale system six,bmc and so on).
But the idea is that the new S5 stem puts the handebar where a conventional stem and steerer tube arrangement puts the handlebar. That means there's no special reason that the new S5 needs a handlebar stack/reach chart any more than a normal bike. (Handlebar stack/reach charts may well be a good idea in general, but if they are then they should be on every bike, not just this one. If they're not, then you can just figure out positioning from frame stack/reach and available stem lengths and {real or virtual} angles on this like you can on any other.)
If you're going to do that then just measure stack from the BB anyway. It's just as easy to measure from the BB as it is from the dropouts, plus you ward off the people who either forget or simply don't understand that they need to account for the BB drop measurement after they've taken the dropout to bar stack.muti wrote:As I have written on another post,the easiest way would be to include a min /max(min=no spacers,max=2/3 1cm spacers)fork dropouts to upper surface of the handlebar(not lower because it does not seem to be round ).Then you can take into account the bb drop and you can be quite accurate on the frame size/stem angle you need.
I would be very surprised if that's something Cervelo would do directly (through Derby in the european market, anyway). It would almost certainly be something you would need to sort out with your local dealer as to whether they would be willing to swap FOC or for a charge.
https://www.cervelo.com/bikes/s-series
The website has been updated.
Gonna need to do waaaaaaay moar dentures.
“We NEED to make the bars/stem like this primarily so we can bury the cables* (lulz!)”
[Buries cables in new S3 just fine...]
In bikeradar's article about the S series they mentioned a new stem/headset design on the S3 bike. From the writen descriptin I have a really vague understanding of what is it all about. Is there some picture or schematics of the new "quill stem" design?
https://www.bikeradar.com/news/article/ ... ies-52993/
The new stem interface borrows from older designs, but in a way that’s bang up to date. Rather than using a standing headset stem clamped to the steerer, the S3 has what resembles an old-school quill stem.
The reason for this design is two-fold. First, in conjunction with the split spacers, it’s easy to height-adjust the cockpit. Second, by making this all one piece, the internal cable routing is far simpler to achieve and that’s also a big reason for the S5’s design.
By using a quill that sits as part of the fork steerer and expands into the stem section, this leaves a large channel through the uniquely shaped steerer to run cables and hoses with no interference.
This makes for smoother, more dependable mechanical cable-runs with no kinks or tight radiuses to navigate, or so Cervélo claims. It’s a serious bit of 'out-of-the-box' thinking, which achieves a damn good-looking bike with impressively clean lines.
Functionality > Performance > Weight
Thats a typo. Theyre talking about the s5. S3 looks like a standard stemmadik wrote:In bikeradar's article about the S series they mentioned a new stem/headset design on the S3 bike. From the writen descriptin I have a really vague understanding of what is it all about. Is there some picture or schematics of the new "quill stem" design?
Sent from my SM-G935F using Tapatalk
