2019 bike roll out jam
Jugi
by Jugi
Internal routing of hoses and outers is cleverly solved with that V stem, but apart from that I don't see anything I like. Hopefully those stems (or integrated bar+stems?) come in variety to choose, that positive angle just looks out of place on a bike as streamlined as this.
jlok
by jlok
It has to be like that as the stem (struct?) is starting lower than a normally slammed stem.
Shrike
by Shrike
Jugi wrote:
Wed Sep 12, 2018 11:08 am
Couldn't agree less. That stem looks perfect on a bike like this. All you have to do is look at any aero bike in comparison to realise how out of date looking traditional setups are.
IchDien
by IchDien
Where do I find €10k...
jlok
by jlok
u still got two kidneys? I think frame set only is better to avoid the 2nd tier wheel set.
Broady
by Broady
Apparently Cervelo are offering a free trade in service for different 'stem' swaps.
mrlobber
by mrlobber
jlok wrote:
Wed Sep 12, 2018 11:14 am
It does, but in the pics, the saddle-to-bar drop definitely doesn't look aggressive.
Geometry charts are going to be really interesting, and I hope Cervelo will provide specific stem stack & reach numbers, otherwise comparison with traditional setups will be difficult.
Stueys
by Stueys
Genuinely different, looks epic to my eye. Interested to see the computer mount solution though...
IchDien
by IchDien
Might they mount it behind the stem ( :shock:)? Didn't cervelo always say mounting it on top was more aerodynamic anyway?
wingguy
by wingguy
mrlobber wrote:
Wed Sep 12, 2018 10:57 am
However, from the side... wingguy, do you know the effective reach of the stem and if different lengths will be available?
IIRC they'll be available in nominal 80mm to 130mm versions. That should correspond to the same range of lengths on the current S5, though there will be less stack adjustment (certainly less for it to still look right). I'd imagine that what's been pictured is either a 100 or 110.
I did ask how the geometry chart would be presented, but they either hadn't fully decided or didn't want to tell me :P I think it'll be stack and reach values taken from the spot where the stem does what it says on the label. I.e. the 100mm stem with no additional spacers puts the bar where a slammed 100mm -7 stem would put the bar on the current S5.
ryanw
by ryanw
IchDien wrote:
Wed Sep 12, 2018 12:17 pm
Already ahead of the game....
IG: RhinosWorkshop
VTR1000SP2
by VTR1000SP2
IchDien wrote:Might they mount it behind the stem ( :shock:)? Didn't cervelo always say mounting it on top was more aerodynamic anyway?
When mounting a computer on a bike equipped with the current aero handlebar, yes, it was faster on the stem.
Focus Izalco Max - 4.84kg without pedals
Cervélo Áspero - 8.28kg
Trek Madone SLR Rim - 7.73kg
Standert Triebwerk Disc - 8.47kg
VTR1000SP2
by VTR1000SP2
I did that on my S3 and it took the top layer of paint off.
mrlobber
by mrlobber
Of course, with the bayonet fork the stem visually seems to be shorter than it effectively is, but I'll need a while to get used to it... although probably, if sitting on the bike, the way how it looks from the side is the smallest problem of them all :D
wingguy
by wingguy
VTR1000SP2 wrote:
Wed Sep 12, 2018 12:38 pm
