3T Ergonova, dent from stem, what do you guys think?
JerryLook
by JerryLook
I bought this used Ergonova bar recently. From the pics online, the paint just looked scuffed up around the clamping area. My thought was I could sand down the whole bar and lose a couple grams anyways.
So when I received it, there is a dent in the bottom, and a ridge on the top of the clamping area. Think it’s just cosmetic, or is it dangerous to use?
I have seen a few other threads about these 3T bars. There were different opinions about whether the bar needed to be replaced or not. I just want to figure out if I am going to keep this one or not.
Thanks
2010 Orbea Opal 54cm
6.4kg
JasperGr
by JasperGr
I wouldn’t descent with a handlebar like that, not for 1 million euro... throw it away my friend and buy a new and proper one
Verzonden vanaf mijn iPhone met Tapatalk
JerryLook
by JerryLook
On the other Ergonovas I have seen with this issue, they just had the ridge on the top. This one has the dent on the bottom too.
And the dent doesn’t sound good with the tap test. The area around the dent sounds hard and sharp, the dent itself sounds dull and muffled.
The seller of this bar didn’t include important info in the listing and pics. It will be going back to him
6.4kg
topflightpro
by topflightpro
That looks more like a crack than a dent.
kode54
by kode54
that looks like it delaminated and part of it got stuck on the stem clamps. i wouldn't ride on this either. beyond repair IMO
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
beanbiken
by beanbiken
To me that looks seriously stuffed. I have a Egonova LTD bar with “minor” clamp marks but that is a straight out cracked. In the bin or back to the seller.
BB
BB
Coffee & carbon
1415chris
by 1415chris
For comparison stripped Ergosum Ltd, visible small stem imprints. Even before I removed the paint it didn't look as bad as the one on the pics above.
maquisard
by maquisard
Buy a new one, that is damaged beyond repair.
A few hundred euros for a new Ergonova bars will be less than thousands on dental bills.
JerryLook
by JerryLook
Thanks for all the replies. I contacted the seller and am sending it back
6.4kg
JerryLook
by JerryLook
I like the 3T Superergo bar also. It looks to have similar reach and drop to the Ergonova. I wonder if it’s close to the claimed 173 grams? I would be getting a 38cm.
This Ergonova I have now is 190 grams in a size 38cm
6.4kg
JerryLook
by JerryLook
1415chris wrote:
Thu Jun 21, 2018 9:34 pm
That’s a pretty good weight. What did it weigh before you stripped it?
6.4kg
pdlpsher1
by pdlpsher1
There’s some talk about the 3T bars having a soft paint in the center to help with friction. I believe this is true as I also have clamp imprints on my bars. Even when torqued properly the imprints will be there. But this is the first time I’ve seen bars that are damaged this badly.
2lo8
by 2lo8
You can see the carbon exposed and fraying in the second picture. Looks like someone overtorqued their carbon bars, heard a crack, and decided to unload them on some poor sucker.
[6.6kg of no carbon fiber]
[2lo8.wordpress.com]
1415chris
by 1415chris
JerryLook wrote:
Fri Jun 22, 2018 12:32 am
Size 44
L3X
by L3X
I wouldnt run that thing in a thousand years. And apart from the safety aspect, you're not going to accept a bar with damage not mentioned by the seller are you...
Understand buying second hand parts because it's a lot cheaper, but bars I would never buy second hand. You never know what the seller did with them and it's very difficult to detect any flaws that are not on the surface. Just bite the bullet, save money for a while, sell a kidney or whatever works for you and be safe :)
