BMC TimeMachine Road 2019
spdntrxi
by spdntrxi
I have that saddle on my TT/Tri bike... not sure I'd want it on my road bike.
AlgaeHater
by AlgaeHater
spdntrxi wrote:
Tue May 28, 2019 8:11 pm
47cm frame helps somewhat :) it was still 1000g+
Pretty stock except.. most bolts are Ti except seat and brake
DA 9150 hydro
THM clavicula se cranks
Garmin vector 3 pedals
Extralite chainrings 52/36
SRAM Red cassette 11/32
KMC 11SL chain
Bontrager XXX saddle
Roval CLX50 with Turbo Cottons
Garmin Mount for 1030 from shapeways
110mm stem instead of 100mm
That’s what I can think of
Wow nice build - some weenie parts I see!
2019 Bianchi Oltre XR4 eTap
2019 BMC Timemachine Road 01 Di2
2018 BMC Roadmachine 02 Di2
2018 S-Works CruX 1X Di2
spdntrxi
by spdntrxi
AlgaeHater wrote:
Tue May 28, 2019 11:07 pm
DA 9150 hydro
KMC 11SL chain
these integrated bikes only let you do so much :noidea: ... bar/stem/seatpost are tanks, imagine if one could DARIMOrize them... I could see shaving 300g
addictR1
by addictR1
spdntrxi wrote:I have that saddle on my TT/Tri bike... not sure I'd want it on my road bike.
I’ve emailed them in the past and they suggested with this combo it’s better to use their road saddle. But to me their road saddles looks awful..
addictR1
by addictR1
ArtifactsInMotion wrote:
Tue May 21, 2019 2:22 am
Perfect. Fit. https://www.probolt-usa.com/titanium-du ... pec-1.html
ImageProbolt Seatpost Bolt BMC TMR01 (Timemachine Road 01)
Side by Side: The steel bolt has slightly more threading, but I measured with my caliper and there's still 3-4 threads when installed with the Ti bolt still. No concerns there.
what's nm do you torque it down to?
cerro
by cerro
spdntrxi wrote:
Wed May 29, 2019 1:49 am
DA 9150 hydro
KMC 11SL chain
Darimo is planning on aero seatposts as next product :D
/jonas l
spdntrxi
by spdntrxi
^ I would get one in a heartbeat OEM w/bolt = 193g
just not sure BMC sales numbers would justify tooling expense for Darimo.. maybe it's easier then I think.. finger crossed :thumbup:
addictR1
by addictR1
spdntrxi wrote:^ I would get one in a heartbeat OEM w/bolt = 193g
I would get one as well!
spdntrxi
by spdntrxi
addictR1 wrote:
Sat Jun 08, 2019 1:20 am
I doubt they would make one... even less so for last gen.
The only prayer would be the SLR01 and RM01 series all share. I know they are roughly the same shape but beyond that I have no idea.
Campervan
by Campervan
I've just had an accident with my Venge so maybe looking for a new aero bike. How are you getting on with the tmr?
BMC Granfondo 02 105
Btwin 540
Specialized Venge Pro Disc
spdntrxi
by spdntrxi
Love mine... blast to ride and comfortable
Might not be as light as the venge.. but not much heavier.. my 48 frame was 1kg.. uncut fork was 470g
Campervan
by Campervan
What's the widest wheel you can actually fit? I'm looking at the new hunt wheels which are 35mm wide with 28mm tyres.
Btwin 540
spdntrxi
by spdntrxi
Campervan wrote:
Mon Jul 01, 2019 12:50 pm
My schwalbe pro one 28 are over 31 on my Enve 4.5AR.. those hunts are wider obvoiusly by 4mm.. hard to say what 28mm tires will measure on those dimension rims. I will say with my 4.5AR&28... it's the height of the tire that has less clearance then the width right now. I doubt that hunt width will make them taller.
TobinHatesYou
by TobinHatesYou
spdntrxi wrote:
Mon Jul 01, 2019 4:51 pm
The Hunt rims use 22mm wide hooked beads, so tires will be narrower than on 4.5ARs.
dorin
by dorin
Does anyone know the difference between the two rear derailleur hangers? 58 vs 59? 59 (301093) is pictured in all publications and pretty much everywhere but my lbs mounted the 58 (3011092). Using it with DA and 11-32 cassette I wonder if it doesn’t put too much pressure on RD and maybe the 59 would be better..
Cheers,
Dorin
