BMC TimeMachine Road 2019
spdntrxi
by spdntrxi
Anybody using the Garmin 1030... seems this CPU is too big for the provided stem mount. I have an 820 which I'm sure is fine.. Hello BMC it's 2019 give us a longer mount and one with a go-pro underneath as well. Hopefully someone does an aftermarket mount. ( need to find my gopro extension kit..more weight)
Also you need long caliper binding bolts (30mm) for the front brake and the rear. Most shimano kits give you a long pair and short pair.. but seems the BMC does not need the use of that 160/140 adapter plate...and is 160mm only in the front..thus long bolts needed.
I'm still missing my extralite 52/36 rings anyways.. so I cant finish regardless.
I also ordered 110mm stem... the bars are redonk short reach...
AlgaeHater
by AlgaeHater
I use a Bolt instead of Garmin. For the mount, I went with an aero 3D printed one from shapeways.com. For the light, I used a universal light mount purchased on Amazon mounted to a GoPro style slide mount attached to the underside of the stem with 3M doublesided tape. The light assembly can be easily slid off with no tools.
2019 Bianchi Oltre XR4 eTap
2019 BMC Timemachine Road 01 Di2
2018 BMC Roadmachine 02 Di2
spdntrxi
by spdntrxi
forgot all about shapeways thanks... ordered and done, someone makes a longer version with gopro mount on the bottom.
g32ecs
by g32ecs
spdntrxi wrote:
Sun Mar 17, 2019 5:09 am
Mind if you take a photo of your frame? Curious how the 47 turned out TTube-wise (horizontal or a slight slope or a super slope like a Madone in a 50)
spdntrxi
by spdntrxi
g32ecs wrote:
Mon Mar 18, 2019 3:02 am
oh... it's not that much slope... that's why I went with a 47 and not the 51... the seattube is long for th size because there is very little slope.
Sitting around waiting for parts ..longer stem, chainrings, di2 wire here and there. Stack will be about 20 less then shown,
dorin
by dorin
Hi there,
Module and AXS groupset at LBS awaiting the Zipp 404 NSW to be delivered next week.
The LBS just informed me BMC told them the AXS requires a dedicated rear derailleur hanger, as the one provided is little shorter and can cause damage to chainstay (they - BMC- already have one case) and no news onsite when they will be able to provide hangers...
I noticed canyon provided the same hanger for axs or di2.
If you are using AXS how did you handle this? I’d hate to switch to di2 but I understood I could use a 11-32 ultegra cassete...
Cheers,
Dorin
spdntrxi
by spdntrxi
my build is DuraAce 9150 hydro... sorry.
I finally cut my steerer today... getting there. Stem and chainrings came in. It looks like a bike now... only thing not on are the chain and pedals and bar tape and brake fluid.
Ettore
by Ettore
dorin wrote:
Tue Apr 16, 2019 11:52 pm
Hi there,
Cheers,
Dorin
BMC part number is 302109 for the AXS hanger. Contact BMC directly with your question if your LBS doesn't hurry with this. +41 32 654 14 54 for the Swiss number, +1 (888) 262-7755 for the USA number.
TobinHatesYou
by TobinHatesYou
The long Garmin mounts on Shapeways are very flexy. Basically unusable IMO, especially with the heavier computers they are meant to hold.
dorin
by dorin
Ettore wrote:
Wed Apr 17, 2019 9:23 am
Hi there,
Cheers,
Dorin
Many thanks Etore,
I will contact them next week (on holidays on the other side of the globe right now). I spoke with LBS today, apparently the provided hanger is abt 1cm shorter causing the Chain to hit the chainstay sometimes rather aggressive. As the AXS hangers will be available just by end of July I guess I’ll use a film or tube to protect the chainstay for 2 months. Thanks a mil for the part number, super useful!
Cheers,
Dorin
Ettore
by Ettore
TobinHatesYou wrote:
Wed Apr 17, 2019 9:38 am
Can you have them printed in Multi Jet Fusion Plastic PA12? I'm thinking about setting up a Shapeways store as well for these kind of parts, and I've found that my designs come out just fine in this material.
spdntrxi
by spdntrxi
that generally might be true... but the BMC mount for the TMR is pretty short overall..it's basically half a normal mount because you still use BMC aluminum stem dohicky. I will have a Garmin 1030 and likely a VIRB hanging from it on occasion.. so if it's flexy it will show.
groover08
by groover08
I bought a long Garmin mount from Shapeways last week, and it’s super-stiff. I’m not sure I agree the statement above based on my very recent experience.
TobinHatesYou
by TobinHatesYou
groover08 wrote:
Wed Apr 17, 2019 9:56 pm
I’ll have to dig out my video of my 1030 bouncing around on a descent.
AlgaeHater
by AlgaeHater
spdntrxi wrote:
Wed Apr 17, 2019 3:54 am
Wow your bike still isn’t complete yet? I bet you’re dying to take ‘er out!
