Light weight through axle for TCR disc
tarmackev
by tarmackev
I’m trying to lighten my TCR disc, I’ve been looking at through axles as the standard ones seem quite heavy.
Is there a “go-to” standard for light 12x142 and 12x100 through axles? Any cheap, light options.
Any help much appreciated.
TobinHatesYou
by TobinHatesYou
I have been using Shift-Up X12 axles without issues.
zmjones
by zmjones
check out the robert axle project and also probably carbon-ti
joejack951
by joejack951
SRAM Maxle Stealth axles are pretty cheap and about as light as any other option.
Front: http://www.jensonusa.com/Rockshox-Maxle ... RjEALw_wcB
Rear depends on length but here are some options:
164mm: https://www.worldwidecyclery.com/produc ... ge-nosto-3
170.5mm (Giant?): https://www.worldwidecyclery.com/produc ... ge-nosto-3
170mm: https://www.worldwidecyclery.com/produc ... ge-nosto-3
174mm: https://www.worldwidecyclery.com/produc ... ge-nosto-2
Cemicar
by Cemicar
DT-Swiss RWS is a "go-to" standard for axles and indeed you can vastly lighten it by removing the head lever which just serves a handy tool other than a hex wrench.
Note I'm not guaranteeing it's compatible with your bikes, especially since no thread pitch is specified.
LeDuke
by LeDuke
I’m guessing Giant uses the Shimano E-Thru standard, which many people make thru axles for. DT and a bunch of others should make one.
Attermann
by Attermann
My Canyon bike uses a 12x100 with a pitch of 1 on the front, i can't find any axles that uses that too, the one on the bike is from dt swiss, i can't even find that anywhere, does anyone know where i can get a lighter one?
TobinHatesYou
by TobinHatesYou
Shift-Up and Robert Axle Project have the biggest selection of axles in whatever pitch and width you need. Keep in mind that you need to know what standard your brand uses...X-12/Syntace, E-Thru, “basic,” etc. You will also want to be aware that a 12x100 thru axle will actually be more like a 12x121-123mm axle and a rear 12x142 will be 12x167-168mm or something like that. It is best to physically measure your old axle before ordering.
In addition, Shift-Up idiotically calls its 12mm thru axles X12, not to be confused with X-12/Syntace.
joejack951
by joejack951
TobinHatesYou wrote:
Sat Jun 16, 2018 8:25 am
Yeah, that had me thoroughly confused when I first saw it. It makes no sense.
tarmackev
by tarmackev
Thanks for the tips and links. I’m on it.
shotgun
by shotgun
tarmackev wrote:
Sat Jun 16, 2018 3:36 pm
Thanks for the tips and links. I’m on it. Image
Checking if you were able to pin down what'll work with your TCR?
2018 Giant TCR Advance SL0 Disc
2017 Festka Scalatore
1989 Battaglin Roche
1985 Alan Carbonio
tarmackev
by tarmackev
I ended up replacing the front one, I can’t remember which one I got but it was one of the smaller sips that does QR’s, top caps, computer mounts and CNC bits.
It’s perfect, picked the Shimano/DTswisd thread and it’s all good.
bm0p700f
by bm0p700f
carbon ti do an axle.
LeDuke
by LeDuke
J&L on eBay.
tomee
by tomee
are all Giant bikes the same length and pitch?
trying to look for a light thru axle for current model propel disc
