SRAM 2019?
jeanjacques
by jeanjacques
Without the 16t cog ? :roll:
Marin
by Marin
jeanjacques wrote:
Mon Nov 05, 2018 9:50 am
:shock:
madik
by madik
so if the 50/37 and cassettes starting at 10 teeth cog is the new "Pro" chainrings standard for 12s from now on. That means sub-kompact like 46/30 will be a new standard (sub-compact) for a general public like the 50/34 is now. What do you think?
jlok
by jlok
madik wrote:
Mon Nov 05, 2018 12:44 pm
WW should embrace 46/30 and 10-28/26/24 for the potential reduction in weight. I said potential, not actual so we shall wait and see.
Karvalo
by Karvalo
Marin wrote:
Mon Nov 05, 2018 12:40 pm
:shock:
The 16t is the 6th cog on a cassette that starts from 11. this one starts from 10, therefore the 15t is the 6th cog, which it does have. It doesn't have the next 1t jump to the 7th cog (17t on a conventional low range cassette) but it's already doing better than most modern mid to high range cassettes.
You could say it's got half of a 16t cog, and on the range equivalent of an 11-31 cassette that's pretty good these days!
I'm still not sure if it's a good idea for Sram to push a system that needs a new freehub, but it's growing on me.
madik
by madik
With 46/30 chainrings and 10-28 cassette you will be on pretty much the same range as 50/34 and 11-32 but with much smaller jumps on the cassette. Also with 46t big ring you could be on 1 smaller cog for the same speed which would mean effectively reducing the "problem" of the missing 16T cog (with 10-28).
For me I would probably like 46/32 with the 10-28 cassette. Just 14 teeth difference between chainrings with similar range as 50-34 and 11-30.
jlok
by jlok
The only thing that's bad for me is the forced change of Quarq power meter to the new one with direct mount rings. Need to sell it...
alcatraz
by alcatraz
:shock:
I made a mistake. It should have the 16t cog if cassette is no larger than 28t.
For 30+32t I don't think it'll have a 16t cog unless it's traditional freehub + 12s.
de lars cuevas
by de lars cuevas
This guys head looks like SRAM HRD Hoods. :D
rainerhq
by rainerhq
Seems like WvA also used new gruppo yesterday at euros.
https://www.velonews.com/2018/11/news/v ... ips_480886
Domane
Speed Concept
"Nothing compares to the simple pleasure of a bike ride"
TobinHatesYou
by TobinHatesYou
The chainrings are machined from a single block for further weight savings. 50/37 for the strong pros, 48/35 for most. Assuming there’s a 46/33 or similar for compact and gravel applications.
Not sure if direct-mount like CT claims. My bet is a really tight BCD and any loss in lateral stiffness is made up by the single-piece construction of the rings. Direct-mount would make things harder for Quarq to design around.
Dan Gerous
by Dan Gerous
rainerhq wrote:
Mon Nov 05, 2018 7:30 pm
I think Wout has been on it a few weeks. Jeremy Powers is using it too, as seen here a few weeks ago in Gloucester.
jlok
by jlok
btw, which current top end direct drive trainer potentially could support this SRAM road 12x?
ooo
by ooo
JetBlack WhisperDrive
https://www.jetblackcycling.com/product ... ve-smart-1
Axle Compatibility with 9mm x 130mm or 135mm, 12mm x 142mm and now BOOST. 148mm BOOST Adaptors sold separately.
Cassette Compatibility Shimano/SRAM 10/11 Speed, Campy, and XD drivers sold separately.
