SRAM 2019?
dudemanppl
by dudemanppl
?? Shimano is all compatible other than 10 speed? eTap is for people who don't like good shifting.
Jugi
by Jugi
dudemanppl wrote:
Sun Nov 04, 2018 7:25 pm
This is exactly what I mean. If I have understood correctly, electronic shifting levers do not include any indexing or logic, as they are just buttons that get pushed. But for some reason, if I had a pair of Dura-Ace Di2 7970 levers laying on a shelf, I can’t use them with Dura-Ace Di2 9150 components although the basic tech is the same? And following the same logic, when the imminent release of 12spd Dura-Ace happens all the 11spd components become antique?
TurboKoo
by TurboKoo
7970 uses different type of electrical cables and hence is not compatible. All other Di2 systems use e-tube and can be used and mixed.
Scott Foil
Shimano 9150
Shimano FCR-9100-P
Shimano C60 tubulars
Ritxis
by Ritxis
Jugi wrote:
Sun Nov 04, 2018 8:04 pm
The technology of the first Dura-ace 7970 Di2, It has nothing to do with the Di2 E-tube (the first Di2 e-tube was the Ultegra 6770 10 speed) you can mix almost all the components Di2 e-Tube,e ven road, mountain and urban (Alfine) components .......(There are very few incompatibilities)
Karvalo
by Karvalo
No, the basic tech isn't the same. Fundamentally, after releasing 7970 Shimano realised that its semi-permanent cabling solution sucked. They developed the Etube cabling system for the release of Ultegra 6770 to offer increased plug and play options. They have now used the same Etube system on 4 road iterations of DI2, 2 MTB iterations and Alfine, with almost complete compatibility between any mix and match of components from any of them. Including the ability to use 10 speed 6770 shifters with 11 speed derailleurs :wink:
Following the right logic, when Shimano release 12 speed, they will probably do exactly what you want them to do, and continue to cater for 11 speed compatibility through firmware changes. Unless there is a major physical change like wireless of course.
wheelsONfire
by wheelsONfire
I still wonder of the angle of the spokes going 12 speed, is it same as 11 speed?
The new freehub bodies, are they wider?
If so, how does it work with the old 130mm rim brake standard?
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
by Nefarious86
dudemanppl wrote:?? Shimano is all compatible other than 10 speed? eTap is for people who don't like good shifting.
The front mech is pretty woeful, rear always seemed ok for me. In saying that I sold my Etap HRD to replace it with 8070...
Using Tapatalk
liam7020
by liam7020
If the freehub standard is changed from HG might be an option to stick a Campag 12 speed cassette onto a Campag freehub. I've used 11 speed Campag cassettes with Etap without issues.
Presently using Record EPS with a DA cassette, KMC chain and Praxis front rings and it works a treat - always prepared to give a bit of mix and match a shot despite whatever bullsh*t the manufacturers spout out!
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
Karvalo
by Karvalo
wheelsONfire wrote:
Sun Nov 04, 2018 9:25 pm
It's all the same, so far. Although Campag is the only 12 speed road that's been released, Sram and Shimano have 12 speed MTB groups out there and so far none of the new freehubs are any wider than before (MTB freehub width hasn't changed since 10speed, even).
themidge
by themidge
If Sram goes 12 speed road (and it seems they will looking at the photos), will they go with Campagnolo spacing on the cassette? Can they? If the they do, will Shimano follow suit and we end up with cross compatibility between all three brands?
Edit: I forgot about Rotor, how do they fit in all of this?
solarider
by solarider
Rotor? FSA? Who cares?! I really can’t see the space in the market for another scale groupset player. As much as I value consumer choice and dislike a monopoly, the new entrants in the market haven’t brought much relevant innovation to play. The big 3 seem to have most of the patents wrapped up meaning any new entrant has to be different for the sake of it to avoid patent infringement. It’s virtually a lockout. SRAM seem to have managed it, but they are the only ones who could introduce a third freehub standard (XD). Looks like we will have 3 freehub standards on the road soon, and I just can’t see anybody else being able to introduce another into an already crowded market.
TobinHatesYou
by TobinHatesYou
The FSA group is vaporware to the consumer as of right now. I do think the Rotor UNO group is interesting. They managed to bring most of the benefits of electronic shifting to the rear derailleur...as in precise indexing, low hand force, etc. The fact that the rear derailleur uses ratchets for indexing is cool when it comes to upgrade paths. UNO front shifting was terrible and it's not surprising Rotor has quickly moved to 1x.
ch00bzs
by ch00bzs
spotted on saitama criterium - katusha team with prototype
by Nefarious86
Using Tapatalk
alcatraz
by alcatraz
Cool. Cassettes starting from 10t. Thats nearly a 10% increase in range.
10-11-12-13-14-15-16-17-19-22-25-28
Edit: Made a mistake of copying the 10s cassette jumps. Now updated with the 16t cog.
