Have you looked carefully at the area right around the crank spindle for damage/crush? Maybe there is enough clearance/taper for them to mate with each other, but I do think I'm correct in stating the old cranks aren't quite the same shape. Look at these side-by-side.
SRAM 2019?
I think there was a misunderstanding with my question.
I'm gonna clarify myself.
So I have bought the new Trek Madone SLR 9 with the new SRAM AXS 12 speed groupset (complete bike => https://www.trekbikes.com/us/en_US/bike ... =red_white)
This bike comes with a regular crankset (no powermeter) and is a GXP spindle version. I think they are gonna call it dub 24?
These GXP versions aren't available yet => will be available in June/July where I live. Just some manufactures like Trek, Pinarello and BMC get some limited quantities at this moment.
Now I wanted to have the Quarq power meter so I asked my shop if the power meter upgrade is already available for the AXS => https://www.quarq.com/product/sram-red- ... -upgrades/
The powermeter upgrades will be, like the GXP spindle, available from June/July where I live.
So my only option I have at this moment is to buy a complete crankset (DUB => bb30) with the powermeter installed => https://www.quarq.com/product/sram-red- ... cranksets/
My question now is, i know the chainrings are direct mount but if I buy the complete DUB (bb30) crankset with the powermeter, can I take off the DM chainrings with the powermeter and install it on my GXP (DUB24) version? Or are the chainrings for DUB (bb30) and GXP (DUB24) different? Or are the cranks arm different?
I understood your question the first time you asked, but others answered with what I assume is correct guidance.
The 8-bolt interface is the same. The power meter chainrings should be interchangeable with any AXS crankset. Any differences like q-factor would be incorporated on the crankarms themselves.
In your case a pedal-powermeter would be the better optionODC wrote: ↑Tue Mar 19, 2019 8:52 amI think there was a misunderstanding with my question.
In my case a the dub crankset will cost me the same as the Garmin Vector 3 pedals.Pinguin wrote: ↑Tue Mar 19, 2019 2:31 pmIn your case a pedal-powermeter would be the better optionODC wrote: ↑Tue Mar 19, 2019 8:52 amI think there was a misunderstanding with my question.
And in my opinion the Vectors are trash.
I went with this option too.... got rid of the vectors and got the powermeter. Saved weight too plus back to Shimano cleats!
ODC wrote: ↑Tue Mar 19, 2019 3:52 pmIn my case a the dub crankset will cost me the same as the Garmin Vector 3 pedals.Pinguin wrote: ↑Tue Mar 19, 2019 2:31 pmIn your case a pedal-powermeter would be the better optionODC wrote: ↑Tue Mar 19, 2019 8:52 amI think there was a misunderstanding with my question.
When we did it there was no fouling on the arms when mounting the rings to the 8 bolt interface. Again, this was not the quarq+rings, it was just rings.TobinHatesYou wrote: ↑Tue Mar 19, 2019 4:09 am
Also interested to know. Have not seen any updates on the topic since Red eTap AXS release.
Current:
S-Works SL8 RTP (build in progress) | Diverge Comp Carbon
Retired:
S-Works SL7 | S-Works Venge | Ultimate CF SLX Mk IV | Ultimate CF SLX Mk III | S5 | R3 | Cento | ...
Retired:
Just for clarity. grover, did you replaced DZero spider with AXS chainring on Quarq BB30 crankarms? Can you make photos?grover wrote: ↑Tue Mar 19, 2019 11:11 pmWhen we did it there was no fouling on the arms when mounting the rings to the 8 bolt interface. Again, this was not the quarq+rings, it was just rings.TobinHatesYou wrote: ↑Tue Mar 19, 2019 4:09 am
Did it because the Cannondale SuperX uses an 83mm wide PF30 shell with chainline of 55mm (Cannondale term it 'Ai'). So needed a long spindle crankset version. SRAM apparently are making an Ai dub road crankset for axs but not yet available.
Awesome! For some reasons I don't want to use DUB cranks. One more real option in addition to aftermarket chainrings.grover wrote: ↑Thu Mar 21, 2019 12:36 amUntitled.jpg
Yes, removed Dzero. Installed AXS rings. That's the best photo I have.
In UK they are showing GXP chainrings as delivery late June.ODC wrote:In my case a the dub crankset will cost me the same as the Garmin Vector 3 pedals.Pinguin wrote: ↑Tue Mar 19, 2019 2:31 pmIn your case a pedal-powermeter would be the better optionODC wrote: ↑Tue Mar 19, 2019 8:52 amI think there was a misunderstanding with my question.
However, if your LBS phones the distributor and commits to a purchase then units can be flown in. That brings the eta to late April.
