Interesting. I just bought a Stages DA L/R for my Venge Pro, will have to test this out!TobinHatesYou wrote: ↑Thu Nov 29, 2018 5:03 amThis is speculation, but it seems like it's very tough to design a PM around the current Shimano cranks due to the asymmetrical DS crank causing torque vector measurement issues. GPLama's Stages LR has a similar problem to the Shimano PM...aka L/R balance issues and the right side reading low.
Has anyone experienced similar lopsidedness with the new Pioneers or 4iiii units built around the newer Shimano cranksets?
SRAM 2019?
2021 Factor Ostro VAM
2021 Factor LS
2018 Trek Speed Concept
2021 Factor LS
I’ll try to grab some closer ones tomorrow.
I guess Wahoo has an XDR driver for the KICKR then?
The real problem is how much SRAM FDs (and Rotor’s FD) suck...especially with non-circular chainrings. It has nothing to do with range or how weak you think we are.
Interesting part about the clutch in the rd (second part of the article). Seems to be in the RED as well as Eagle version. I am wondering if there will be a short/long cage version of the RED rd or if they are going the same way as campy on the 12sp.
https://bikerumor.com/2018/12/04/patent ... railleurs/
It's a CX bike. I doubt you'll need one on a road bike, but I'd probably run one anyway.
More interestingly, why Aqua Blue didn't run a chain guide if it was such an issue?TobinHatesYou wrote: ↑Sun Dec 09, 2018 1:29 pm
I don’t have to run one on my XC bike, defo shouldn’t have to for CX where it risks getting gunked up, may as well have a front mech (not a SRAM one though. Obvs).
Monkeyfudger wrote: ↑Sun Dec 09, 2018 2:06 pmI don’t have to run one on my XC bike, defo shouldn’t have to for CX where it risks getting gunked up, may as well have a front mech (not a SRAM one though. Obvs).
Chainguides are all over pro CX. Maybe it's part K-Edge sponsorship, maybe not. Sven Nys's Boone from a couple years back had a chainguide made out of a DA chainring (Treks already have integrated inside chain catchers.)
Sven's bike
Anyway, not seeing an issue... It's not even a SRAM part and there's no indication that it's a requirement.
That bike doesn’t have a clutch so needs a chain guide, like I said, disappointing. I spent years *f##k* about with chainguides when I was racing DH, I’ll avoid ‘em these days if I can. If a 1x system that’s not on an Enduro/DH bike needs a guide I’d rather just run a front mech, at least I can run a close range cassette then.
Edit - if he’s running it it’s a requirement
inventions in cycling industry are done...
- Dan Gerous
