SRAM 2019?
Don't quote me on this, but you might be able to use the road / eTap AXS 1x chainrings with Eagle chains.
- Moderator
How? The roller diameters dont match up.
Using Tapatalk
Because the tooth spacing on the chainrings is still the same (the troughs are a bit deeper though.)
Anyway I found the mention in the official SRAM documentation.
Hmm, interesting. Thanks
Doesn't this faq answer confirm axs crank + eagle chain compatibility?
How far does such a compatibility go I wonder. Maybe the axs mtb chainrings have a special tooth profile that preserves a level of crosscompatibility?
- ultimobici
- in the industry
- Contact:
https://www.sram.com/sites/default/file ... ents_a.pdfalcatraz wrote:Hmm, interesting. Thanks
- ultimobici
- in the industry
- Contact:
You’re comparing full retail with discounted to compete with the internet prices?pdlpsher1 wrote:By the way the Dura Ace chain is $35 at my local bike shop. So the Force is now competing with Dura Ace?
I remember when SRAM road stuff initially launched the strategy they were allegedly following was that of very aggressive OEM pricing to drive adoption but full retail was higher to compensate (+/- to make the kit "appear" more high end and attractive).
Seemed to work for a while but as their cable stuff became relatively less attractive compared with Shimano (less novelty, no-one cared that it was light because it just doesn't work as well as Ultegra) you don't see many OEM bikes with it installed.
Perhaps they will return to this model? I think we can expect very reasonably priced Canyons with AXS gruppos. I'm slightly reassured that the two consumable elements are half the price with Force.
In the UK OEM kit bleeds readily in to the rest of the supply chain so only later will we see how low the street price of Force will go. Spartan; if these prices really were going to improve the cash flow of the LBS that might be a good thing! It won't.
That seems like it. Canyon Aeroad/Ultimate with AXS is the same price as DA.. sucks that Canyon is not offering the bike with the PM as upgrade. I hope that the street prices are going down, nur I am not betting on it in the next months.petromyzon wrote: ↑Mon Feb 11, 2019 8:19 amI remember when SRAM road stuff initially launched the strategy they were allegedly following was that of very aggressive OEM pricing to drive adoption but full retail was higher to compensate (+/- to make the kit "appear" more high end and attractive).
The ~2500 euro at german online retailers is the "upgrade set" with derailleurs, shifters, calipers and rotors. Force 1850€ is quite a big step up from the same Ui2 kit which can be found for ~1200€.
Current:
S-Works SL8 RTP (build in progress) | Diverge Comp Carbon
Retired:
S-Works SL7 | S-Works Venge | Ultimate CF SLX Mk IV | Ultimate CF SLX Mk III | S5 | R3 | Cento | ...
Retired:
Most roads actually are gravel though.
Haha, I thought someone would say that, allow me to clarify;
Not in countries where people can afford to buy bikes with Sram on them.
I hope SRAM clarifies this a bit better. The new Red 1x chainrings aren't branded AXS, they're branded X-Sync. So can you actually pair a Red12 chain and cassette with a Red12 X-Sync chainring? If you can, why can you then use an Eagle12 chain with either Eagle X-Sync or Red X-Sync rings, but only use a Red12 chain with Red X-Sync and not Eagle X-Sync rings?TobinHatesYou wrote: ↑Mon Feb 11, 2019 6:48 am
They've done a very poor job communicating the mechanical compatibility.
- ultimobici
- in the industry
- Contact:
Whichever cassette is used dictates which mech and chain are used. Red AXS cassette = flat top chain & Red AXS mech. Eagle cassette = Eagle chain & rear mech. Provided your chainring is 12s you are good to go.
So does that mean that a 12 speed KMC and (for example) a 12 speed Campy cassette would work, at least possibly?
