Preferred Wheelset For F8/F10.
tabl10s
by tabl10s
I thinking about using Zipp 454's as a pseudo aero setup. Anyone using this combo?
2016 Orbea Orca OMR:
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
2015 Pinarello F8(build in-process).
TobinHatesYou
by TobinHatesYou
Just get 404s if you go the the Zipp route. The 454s aren't as aero and only marginally more stable in crosswinds. About what you'd expect for a wheelset with an average depth less than that of the 58mm 404s.
spdntrxi
by spdntrxi
what Tobin said
TonyM
by TonyM
I have the DT Swiss aero wheels on my F10.
DT Swiss ARC 1100 Dicut 48. Also available in 62mm and 80mm.
tabl10s
by tabl10s
TobinHatesYou wrote: ↑
Wed Jun 13, 2018 2:15 am
If that's the case, I stick with the Roval's and get a pair of 32's
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
TonyM
by TonyM
Why not the CLX50?
TobinHatesYou
by TobinHatesYou
tabl10s wrote: ↑
Wed Jun 13, 2018 5:21 am
That’s a pretty significant difference in rim depth from 53-58mm to 32mm. It really depends on what you want. I ride 32mm rims most of the time lately because it’s been incredibly windy in the Bay Area this spring. With no winds I usually ride ENVE SES 5.6s (54/63mm.)
tabl10s
by tabl10s
TonyM wrote: ↑
Wed Jun 13, 2018 5:47 am
Why not the CLX50?
I have both 50's and 64's. I just want to finish the trio.
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
MRM
by MRM
Campagnolo and Bontrager have new 60 mm wheels out worth checking out. They are lighter than the Zipps. If I remember correctly the Bontrager are 1520g for the set (clinchers) and the Bora WTO 6 are 1550g.
Bridgeman
by Bridgeman
With my F10, I'm currently running a set of de-labeled Bontrager Aeolus D3 5 and another set of D3, with a 3 in front and 5 for the rear for windy days. All are tubular. They are fast and handle gusty side winds extremely well.
Will be looking into Bora Ultra 50 soon.
Beaver
by Beaver
Sorry for beeing the party pooper again: The difference between Zipp 404 and 454 is ONE watt at 45 km/h where you will need 450 watts overall. That's absolutely unnoticable - as well as the difference to other wheelsets of equal height and width. ;)
With low box shaped rimmed, thick spoked Ksyrium Pro and strong head winds from high angles, the difference will be around 20 watts, that you could notice.
wszs91
by wszs91
I went with mavic cosmic pro carbon sl ust, good wheels overall
