rear brake under chainstay pros and cons in general - scott foil rc specifically
jlok
by jlok
@FIJIGabe
Good to know and yes it was a first gen Stage. Finally need to file down the Ultegra brake to make room. I saw quite a lot of people doing that.
Also someone told me to dremel the end of a brake wire housing to prevent mushy feeling upon braking.
FIJIGabe
by FIJIGabe
I've tried different housings, Shimano, Jagwire & Yokozuna, and they all feel mushy. That said, since it's the rear brakes, I'm not too concerned (my front-mount brake is fine). My new Madone doesn't have these issues.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
Madone 5, Cobia. I own a lot of Treks.
Delorre
by Delorre
tarmackev wrote:
Wed Jun 13, 2018 1:30 pm
Don’t know anyone who owns a Foil who ever had a problem with the brake.
Except some have issues with rear brake rub (also a few over here if I remember) and others not. Not clear why and what the factors are to make this happen or not....
kode54
by kode54
i have direct mounted brakes on my Parlee ESX...and eeCycle brakes.
looks nice and clean since brakes are not mounted on seat stays...although they get 3-4x more dirty. I'm actually surprised that the brakes still work after a ride in damp or wet road conditions. even at that...after one ride on dry roads...its still filthy. Since I don't frequently look under the chain stays...i tend to not clean it as much as I should...and when I do clean the brakes, its much more often than seat stay mounted brakes. The eeCycle brakes work well even when I don't clean it as much as I should.
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
ZONE1090
by ZONE1090
Just got my 2018 Merida reactor DA limited. Love the bike! Setting up the rear brake is kind of a pain. Here's what I did:adjust 2 turns out on cable adjuster, loosen cable clamp, squeeze caliber together ,tighten cable as tight as you can, adjust cable tensioner to proper air gap.
JeffK
by JeffK
octave wrote:
Fri Jun 15, 2018 2:44 am
JeffK wrote:
Thu Jun 14, 2018 3:40 pm
I have a 2016 Foil Premium frame I built up with DA9150 Di2 and DA9110 direct mount brakes. I have not had a problem with the rear brake whatsoever. If you clean and maintain your bike regularily it is not an issue. I also have Enve 5.6 wheels and the braking is perfectly fine as compared to my other rim brake bikes. I would not hesitate to buy one again.
is that a size 56? how many CMs of spacers under the stem? i ride a 56 first gen foil with 2cm of spacers plus the 1cm headset cover, so i am just trying to envision what a new gen foil would look like in my setup.
Mine is a 54 with about 1cm of spacers under stem.
pmprego
by pmprego
I've searched everywhere. I have a potential new bike that has a rear brake mounted bellow the bb. Can anyone explain or show me a link with explanation for how to "unlock" the rear brake in order to remove the rear wheel? I frequently have to do this due to kickr and on regular brakes is as easy as pulling the small lever on the brake.
kode54
by kode54
depends on what brand of brakes you have installed.
jih
by jih
pmprego wrote:
Mon Jan 21, 2019 3:19 pm
Probably the same as with the brake on the seatstays? Quick release on either the brake(shimano, sram) or the brake lever (campag)
Or, just get wider rims so you don’t have to let the brake out to remove the wheel 8)
CAAD8FRED
by CAAD8FRED
For shimano, the grey lever on the rear brake cable opens and releases tension.
K4m1k4z3
by K4m1k4z3
Me & my mate recently got the new Specialized PowerMeters (made by 4iiii) Ultegra left crank upgrade kit.
Turns out he can't fit it on his bike. His frame is a SUPERIOR (Czech brand) with Shimano direct mount brake underneath the BB. The brake body interferes with the plastic cover. Can't even spin the cranks.
Yikes.
Giant TCR Advanced Pro 1 Disc '18
KotP
by KotP
Inline brake cable adjuster.
Or depends how much exposed brake housing there is at the downtube/BB you can put the inline adjuster there.
KotP
by KotP
K4m1k4z3 wrote:
Wed Jan 23, 2019 12:01 am
Yikes.
Too little, too late for your friend but he could of tried this: https://4iiii.com/wp-content/uploads/20 ... 170215.pdf
K4m1k4z3
by K4m1k4z3
KotP wrote:
Wed Jan 23, 2019 3:59 am
Yeah. I knew about this and I had done that exact test on my TCR beforehand. Funnily enough I performed the test with him present there. I guess he just wasn't focused and later he forgot or it just didn't occur to him. To make matters even worse he recently ordered and received some TRP brake caliper that should've fixed the problem. Turns out there's an issue with the brake bosses (hope that's the correct terminology). The Shimano one has them built into the caliper, they go through the chainstays and bolts fix them on the other side. The TRP however comes without bosses. Yikes.
Looks like all this chain of events is doing is speeding up his decision to buy a new bike altogether. =D
Kalliastar1
by Kalliastar1
I ride a Fuji TT 2016 model wich has te TRP brake callipers pre- mounted.
the issue is that rear brake's wire end at the crankset's side and space it so short that it gets really close to the chainring!
I guess this is the older model of TRP TTV version and I'm looking to purchase a newer version, BUT I have to order it online, becaause there is no retailer in my counttry!
I can't figure if the wire of the newer version of rear brake calliper ends at the oposite side of crankset.
any advice/help?
thanks
