Campy thru axle?
DT Swiss certainly make a conversion kit to change their ratchet hubs to a Campagnolo freehub on a 12/142 thru axle. Part number HWYABX00S7154S. e.g. https://www.bike-components.de/en/DT-Sw ... em-p62834/.
I presume you should also be able to buy the hub from scratch with that freehub installed.
- Contact:
I am not certain of the exact question but I have two Campagnolo freehub bodies for Bitex hubs that work with 12mm thru axles.
Yes - but free hub bodies are specific to hubs. No one can tell you if the part is available for your wheels without you saying which wheels you have.
How about you describe your situation so we're all on the same page?
It sounds like you've jumped ahead from a mistaken assumption like all cassette bodies are interchangeable or something.
I'm trying to find if the free hub will work with a Wahoo trainer....bm0p700f wrote:WHat wheel does the op have? Freehubs are wheel specific. This question almost no sense without a wheel in mind.
And I'm asking here because Wahoo support is clueless...
I have the Wahoo Kickr17 that supports thru axle, etc.
From the comments on the DCrainmaker
https://www.dcrainmaker.com/2017/08/han ... ition.html
"The new model 2017 is no longer compatible with the current campagnolo freehub adaptor."
Which I suppose means use a 11 speed Shimano cassette if you are on a Campag 11 groupset, and no luck for Campag 9 or 10 (except adaptor cassettes in some form).
