Didn’t get a bike fit at the shop so it’s all default positions apart from the saddle height. The only adjustment I’ve made is the saddle height.TobinHatesYou wrote: ↑Mon Jun 04, 2018 10:07 pmYou’re rolling your shoulders forward a bit and your elbows are almost locked. Basically it looks like you’ve adapted the TCR to fit like a Defy, but the stem is still a bit too long.
Stem lengths on a Giant TCR
Try moving your saddle as far forward as possible and point it downward.
I’m 5’ 11” with a 33” inside leg. I had a fit done before buying the bike and I was in between the stack and reach of most endurance and race bikes. The TCRis a bit longer and Lowe than a Canyon Ultimate but I wanted to buy locally and there was no Di2 Supersix Disc model available in the UK. I test rode the defy and the synapse but they just felt lacklustre and the acceleration of the TCR was great. I’ve since returned to the same fitter who has fitted the bike to me and I have dropped the stem by 10mm to be conservative at first but I think I’ll drop it further after I’ve ridden it for a bit longer and possibly go back to the 110mm stem too, maybe one with a -6 degree rise over the standard giant -8.devonbiker wrote: ↑Mon Jun 04, 2018 2:00 pmWhat's your height? I've just ordered a 100mm Contact SL stem from Tredz (£42.99). Hopefully that small difference will do the trick.MattAttack wrote: ↑Mon Jun 04, 2018 1:25 pmI have just had a fit on my TCR Advanced PRO 0 disc (M/L) and the fitter swapped the 110mm stem for a 100mm. With the stems side by side they don't look to be 10mm different but you can feel it when you ride it.
I'll see how I get on with it (stem's are only about £25) but might go back to putting the 110mm on once I'm a bit more used to the bike.
How are you getting on with the Advanced Pro 0 disc? Love the look of that bike. I went for the Advanced Pro 1 which looks similar (red logo instead of chrome) and mechanical Ultegra and rim brakes.
The day I brought it back from the shop (not setup yet perfectly yet). Has a different saddle now and a few other tweaks but I love the discs and di2, albeit an expensive option over the model below.
Because...?northwestern wrote: ↑Mon Jun 04, 2018 10:23 pmTry moving your saddle as far forward as possible and point it downward.
this is bad advice i agree. this puts you in a more tt-esque position where you can handle big saddle-bar drop. it ain't for cruising about though. definitely doesn't fit the OPs situation.wingguy wrote: ↑Mon Jun 04, 2018 11:36 pmBecause...?northwestern wrote: ↑Mon Jun 04, 2018 10:23 pmTry moving your saddle as far forward as possible and point it downward.
To the OP - that bike is the correct size for you so stop worrying. The question is whether or not it is the correct bike for you. If you can get comfortable with your torso more horizontal than you may be OK. But some body types just don't get along with a more aggressive position. A shorter stem, shortest reach bars, spacer tower, etc will all help, but ultimately the solution is to have a bike with geometry that makes you happy.
Well the Defy I felt too upright and wanted more of a stretch. The TCR is the opposite situation. The TCR is definitely what I am looking for but just needs the slightly shorter stem to make it more comfortable for longer rides.Mr.Gib wrote: ↑Tue Jun 05, 2018 12:25 amTo the OP - that bike is the correct size for you so stop worrying. The question is whether or not it is the correct bike for you. If you can get comfortable with your torso more horizontal than you may be OK. But some body types just don't get along with a more aggressive position. A shorter stem, shortest reach bars, spacer tower, etc will all help, but ultimately the solution is to have a bike with geometry that makes you happy.
Bear in mind I have only taken the TCR out once and that was a 55 mile ride so was out for over 3 hours.
[/quote]
[/quote]
That’s good to know.
[/quote]
- onemanpeloton
How is anyone supposed to help you?
You post pictures of yourself and then say "well thats not actually my normal riding position".
The guys on here are super helpful but you've got to learn to help yourself too. No good bike fitter is going to offer fit advice based on a static photograph and nor can/should anyone else.
2020 Trek Boone
2017 Merida Reacto
2017 Trek Superfly AL
2017 Merida Reacto
You are right - it's hard to adopt a natural riding position when you are leaning against a fence. I will set up my camera and tripod in the park and will video myself cycling past and grab some stills. I agree the people here are very helpful and I am very grateful.onemanpeloton wrote: ↑Tue Jun 05, 2018 9:15 amHow is anyone supposed to help you?
Beautiful bike. One of my favouirtes of all the Giant paint jobs. Love the chrome!MattAttack wrote: ↑Mon Jun 04, 2018 11:13 pmI’m 5’ 11” with a 33” inside leg. I had a fit done before buying the bike and I was in between the stack and reach of most endurance and race bikes. The TCRis a bit longer and Lowe than a Canyon Ultimate but I wanted to buy locally and there was no Di2 Supersix Disc model available in the UK. I test rode the defy and the synapse but they just felt lacklustre and the acceleration of the TCR was great. I’ve since returned to the same fitter who has fitted the bike to me and I have dropped the stem by 10mm to be conservative at first but I think I’ll drop it further after I’ve ridden it for a bit longer and possibly go back to the 110mm stem too, maybe one with a -6 degree rise over the standard giant -8.devonbiker wrote: ↑Mon Jun 04, 2018 2:00 pmWhat's your height? I've just ordered a 100mm Contact SL stem from Tredz (£42.99). Hopefully that small difference will do the trick.MattAttack wrote: ↑Mon Jun 04, 2018 1:25 pmI have just had a fit on my TCR Advanced PRO 0 disc (M/L) and the fitter swapped the 110mm stem for a 100mm. With the stems side by side they don't look to be 10mm different but you can feel it when you ride it.
Thanks! The red is so neon its almost orange.devonbiker wrote: ↑Tue Jun 05, 2018 9:31 amBeautiful bike. One of my favouirtes of all the Giant paint jobs. Love the chrome!
