Pretty close to what I surmised a page earlier.NiFTY wrote: ↑Sat Jun 09, 2018 1:30 am
So the range of error averaged 2-4% with a maximum of 4.5%, and that was with Osymmetrics. With a q ring which has less ovality and less of a cam design this error will be smaller as the angular velocity will change less over the course of the pedal stroke. Therefore the approx +2% for Q rings seems to be about right, and likely a bit more for QXL. If you only run ovalised rings I don't see ths as an issue at all.
Ovalized rings, anyone?
The angular velocity is never constant during the course of the pedal stroke, so I wouldn’t say that. It may vary since angular velocity will vary with each single pedal stroke... But if you are not worried about that, it’s fine, as long as you get consistent numbers between sessions you can do your training just fine.
- IrrelevantD
I'd second this. From my experience with Absolute Black, oval rings tend to promote spinning at higher cadence, and as such staying in the saddle a bit more. I honestly don't notice the difference as much when stomping up hills out of the saddle at 70-80rpm, but when seated and spinning 90-110+ rpm, I can really tell the difference in how much effort it takes to get my leg back over the top of the stroke from about 8 to 2 o'clock. I personally find it's much easier to hold higher power and higher cadence and just grind up hills with oval rings than I was doing before with round rings.TobinHatesYou wrote: ↑Thu Jun 07, 2018 7:38 amI spend 99% of my time in the saddle on round rings.
Out of the saddle climbing for me has never been smooth with round rings because it feels like my pedal stroke wallows at bottom-dead-center. With oval rings, I get much less of that feeling of dead time between alternating peak power phases. Doesn't mean I make a habit of doing it much more often, but I definitely despise it less than with round rings.
