Tune Komm-Vor and WR Compositi WRC compatibility
I am having an issue with Tune Komm-Vor saddle and WR Compositi WRC seapost (27.2).
Does anyone know if I can change the carbon rocker and yokes and make those two compatible?
Thanks!
Thanks!
what is your issue
Solved it - returned the saddle.
The rails were too wide apart than the rockers and yoke of seatpost could handle. And also too bulky.
Hi all,
this thread is alive again
I would love to pair Tune Komm Vor sadlle with WR Compisiti WRC seatpost BUT I need to change the rocker and yokes to make this combo compatible.
Tune website states that VOR's rails are 8 x 9 mm (funny, when you choose German language they are 8 x 10 mm )
Thank you
Thank you
I had that problem on one of my bikes. Solved it by using a clamp from a saddle bag to bring the rails together while mounting the saddle to the seatpost.
Thanks, but Tune sadlle has carbon rails that are also higher and wider than usual.
Have you had any luck?
I'm interested as I'm trying to fit a Tune Speedneedle to a Lyti seatpost.
The cradle doesn't fit...am thinking about filing cradle
I emailed Tune about buying a cradle that would fit and just got a generic unhelpful reply
Building Spec Allez
Sold
Fuji SL 5.5kg viewtopic.php?f=10&t=157704
Sold -
Izalco Max Disc 6.7kg http://weightweenies.starbike.com/forum ... o+Max+disc
Sold
Sold -
NO.
I was thinking if Tune's yokes and rocker would go on the WRC seatpost.....
Does anyone know if Tune sadlle will fit with Hylix seatpost?
