S-Works Venge 2019
Visus
by Visus
Does somebody know what's the difference between the black and the grey/yellow frame or is able to measure it?
ryanw
by ryanw
dns76 wrote:
Mon Oct 08, 2018 4:30 pm
7.17kg ....:twinkle: ..size 52, 130mm stem, excluding swat multitool.
ETap with Dura Ace discs.... Any reason for this?
'16 Cervelo S5 - 6,650g
'17 Focus Mares Force 1 - 7,800g
‘18 Ibis Ripmo - 13,870g
tommyb
by tommyb
Nice! Does the frame come with a bung to cover the di2 junction box hole in the post?
dns76
by dns76
ryanw wrote:
Mon Oct 08, 2018 9:13 pm
with the previous vias the original disc gave me resonance vibbrations problems
dns76
by dns76
tommyb wrote:
Mon Oct 08, 2018 9:57 pm
Yes
RedOne
by RedOne
Finally also photos from my build :)
(7.78 kg as displayed)
Legs speak louder than words
2011 S-Works Tarmac SL3 (7.03 kg)
2014 Specialized Enduro Expert (13.04 kg)
2019 S-Works Venge SaganCollection (7.78kg)
ODC
by ODC
sun wrote:
Fri Sep 21, 2018 5:23 pm
I recently bought a Venge Pro. I swapped the wheels to the CL 64 and did my first ride yesterday. Are the discs supposed to rub whenever out of the saddle? I adjusted the rotors/calipers by loosening the caliper bolts and squeezing on the brakes while tightening the calipers. This my first ever disc bike, so I'm not sure what to expect. The rotors seem true.
Did you get a sollution for this problem? My dad has the same problem with his venge.
Stitchking
by Stitchking
While that is the most straightforward way to align a caliper, it doesn't always work. You need a workstand where you can spin the wheel and make sure the caliper is properly aligned. Also make sure to reset the pistons before you realign a caliper as they may be pushed further out on one side than the other.
Sent from my SM-G935F using Tapatalk
sun
by sun
I didn't really find a solution. I tried multiple things and then it just kind of went away. I'm guessing there is some break in required. Otherwise, it sounds like some rubbing is just normal with disc brakes.
ODC wrote:
Tue Oct 09, 2018 7:01 pm
andreas
by andreas
sun wrote:
Tue Oct 09, 2018 9:20 pm
Lol, there goes those aero gains out of the window...
spartan
by spartan
roval clx wheelsets are flexy. try using another disc wheelset to see if the disc rubbing goes away.
Current Rides:
2018 Madone SLR DISC DI2 9XXX
2017 Giant TCR Advanced SL 0 DI2 9150
by Nefarious86
spartan wrote:roval clx wheelsets are flexy. try using another disc wheelset to see if the disc rubbing goes away.
Yeah no, they are a DT based hub that interface the same as many other hubs, the brake rub isnt caused by the wheel itself in a disc application, also dont know what wheels you have ridden but I've had several sets of CLX in varying depths and they're all stiff as buggery.
Using Tapatalk
Jugi
by Jugi
spartan wrote:
Tue Oct 09, 2018 9:58 pm
I’m sorry for my lacking technical knowledge - which components in a wheel are so flexy, that they affect the brake disc’s position in relation to the brake caliper? I can understand the concept of a rim rubbing a rim brake caliper, but a disc brake caliper is quite close to the hub and the brake disc is a part of the hub.
by Nefarious86
Rims and frames flex, hubs dont.
Using Tapatalk
ryanw
by ryanw
Nefarious86 wrote:
Wed Oct 10, 2018 6:56 am
This.
The wheels have probably been built by some numpty, like the one who built my Enve 4.5s.
Once I had a proper wheel builder lace / tension them correctly, it was like owning a new set of wheels.
