S-Works Venge 2019
andreas
by andreas
I absolutely advise against getting anything in matte white, when you get some oil or dirt there it will smear into the surrounding area when you try to clean it off.
Black/white is easier to match with all kinds of kits, which is why I prefer those frames.
spdntrxi
by spdntrxi
andreas wrote:
Thu Sep 13, 2018 6:13 pm
there are cleaning products that will take care of matte white well.. I rode a bike that was have black and white in matte and chemical guys cleaner did wonders.
anykarthik
by anykarthik
I bought the Matt black Venge Pro. I REALLY wanted to get a non-black bike and would have pulled the trigger on the purple bike, but metal flake is too much bling for my weak legs. If it was a matt or gloss purple without the flake, I would have gone that route. Of course, the extra weight that comes with non-black paints was also a factor. I read somewhere that the purple-flake bike is ~150-200g heavier.
That said, the hologram logos, saddle and bar tape actually make the matt black bike look quite interesting. So no regrets really.
andreas
by andreas
spdntrxi wrote:
Thu Sep 13, 2018 6:35 pm
I tried Morgan Blue matte carbon cleaner, and it did nothing for me. I then tried with WD40 and Citrus Cleaner in desperation as well. May have been too long between getting the stains and cleaning them. I ended up coating my bike in silicone spray after that to avoid any further mess.
RussellS
by RussellS
anykarthik wrote:
Thu Sep 13, 2018 6:39 pm
You are ASSuming the "black" comes from the natural color of the carbon fiber. But more likely if it is painted black, then a black bike weighs the exact same as any other color of bike. I doubt black paint is any lighter weight than white paint or red paint.
cerro
by cerro
Which size? My Purple in 52 is coming any day now :) Got my Aerofly II in 38cm today, 213g :)
/jonas l
sivan
by sivan
RussellS wrote:
Thu Sep 13, 2018 7:34 pm
I`m ASSuming you have to use a thicker layer of white paint then black...
anykarthik
by anykarthik
sivan wrote:
Thu Sep 13, 2018 8:53 pm
Also, in this specific case, metal flake paint is heavier than regular paint.
anykarthik
by anykarthik
cerro wrote:
Thu Sep 13, 2018 8:09 pm
Got the 54. Fits me well. Though I may have to go back to my Selle SMP saddle which would be shame since the hologram saddle cover on the stock Power saddle is pretty damn cool
euan
by euan
Black paint is surprisingly transparent. The metal flake bikes will be painted black before the flake, but I'd be surprised if they are adding more than 25g of flake to the binder and a lot of that will end up on the floor of the spray booth. Will need to burried in extra layers of clearcoat though
andreas
by andreas
Can the spacers be moved to the top of the stem, or does one have to cut the steerer when slamming? This setup looks pretty awful.... Image
wingguy
by wingguy
It is painted black - but with a black carbon backing you only need a small thickness of black paint to get the uniform finish you want. With lighter colours you need enough paint layered up to be completely opaque. If you ever chip the paint on a white or fluoro bike you'll see how much is needed!
RussellS
by RussellS
wingguy wrote:
Fri Sep 14, 2018 12:23 am
You really believe million/billion dollar Specialized "custom" builds every bike it makes? Factories, whether in China or USA, DO NOT vary the routine for everything they produce. That is inefficient and leads to bankruptcy. You honestly believe black bikes are painted differently than white bikes and red bikes? Other than the color, everything is identical. All Specialized bikes built at the same Chinese factory get the same paint job. Costs skyrocket when you change things for every product. Every bike gets two coats of primer, every bike gets two coats of finish color, every bike gets two coats of gloss topcoat. Efficiency keeps costs low and profit high. Variation in every product you make increases costs and lowers profit.
DCcyclist
by DCcyclist
andreas wrote:
Thu Sep 13, 2018 11:21 pm
Can u buy this bartape separately?
Jugi
by Jugi
RussellS wrote: You really believe million/billion dollar Specialized "custom" builds every bike it makes? Factories, whether in China or USA, DO NOT vary the routine for everything they produce. That is inefficient and leads to bankruptcy. You honestly believe black bikes are painted differently than white bikes and red bikes?
Using unneccessary amounts of paint will lead to bankruptcy, as well.
