pmprego
by pmprego on Sun Sep 06, 2020 2:17 pm
TobinHatesYou wrote: ↑Wed Aug 26, 2020 5:25 am
spdntrxi wrote: ↑Wed Aug 26, 2020 2:37 am
while I resemble that remark
... the 1030 was released quite a bit before the 830. I probably would have chosen the 830 if they had be out at the sametime....thus I have a 1030.
Exactly this. When my 520's battery got down to barely 9 hours per charge, there were only three Garmin upgrade paths: 520 Plus, 820 and 1030. I went with the 1030 because it had amazing battery life and it had a much more responsive UI than the 820.
I'm just watching the tour and thinking: there you go, a plus for big GPS units!!
Use them as a tt position stabilizer.
spdntrxi
by spdntrxi on Sun Sep 06, 2020 6:23 pm
pmprego wrote: ↑Sun Sep 06, 2020 2:17 pm
Ive always done this... just dont forget the lock the screen, otherwise you might end up with weird stuff in your fields
CasualRider
by CasualRider on Mon Sep 07, 2020 10:14 am
aeroisnteverything wrote: ↑Thu Sep 03, 2020 11:44 pm
Campervan wrote: ↑Thu Sep 03, 2020 1:34 pm
Do the new rapide 35mm wide front wheels fit the current Venge?
Yep, no problem. Just fitted them - have not yet ridden (tomorrow!) Loads of clearance left.
Venge plus new Rapides - the best bike I've owned so far.
Purple Venge
Trek Madone SLR 7 retired
Campervan
by Campervan on Mon Sep 07, 2020 1:00 pm
CasualRider wrote: ↑Mon Sep 07, 2020 10:14 am
What size did you fit?
BMC Granfondo 02 105
Scott Scale 940
Boardman CXR 9.4 cxr CX/gravel mongrel
Btwin 540
Specialized Venge Pro Disc
CAAD8FRED
by CAAD8FRED on Mon Sep 07, 2020 2:12 pm
What wheels did you have on before and
Do you think the wheels alone improved the ride or did you already like the ride more than anything else
aeroisnteverything
by aeroisnteverything on Mon Sep 07, 2020 2:39 pm
I had CLX 50s before and to me the bike was just as good before. The front on the Rapides is more stable. That is the most readily apparent difference. Plus the much louder free hub (I really liked the quiet of the CLXs - might need to take the hub apart and add some grease to make it less noisy).
Campervan
by Campervan on Mon Sep 07, 2020 3:40 pm
aeroisnteverything wrote: ↑Mon Sep 07, 2020 2:39 pm
What tyre did you go for on the front?
Scott Scale 940
Btwin 540
CasualRider
by CasualRider on Mon Sep 07, 2020 6:19 pm
Exactly my experience. Coming from CL 50s. I belive internal width is slightly larget on new Rapides which translates into a better confort. It can be windy where I live, definetly feel the difference in cross winds and better stability and complance overall. The best wheelset I've owned so far. Running Contis 5000 28mm. Extremelly happy with this setup.
Purple Venge
aeroisnteverything
by aeroisnteverything on Tue Sep 08, 2020 10:23 am
Campervan wrote: ↑Mon Sep 07, 2020 3:40 pm
Vittoria Corsa TLR, 25mm. Looks like this on the rim - you can see the lip but not that much when fully inflated.
AyBee
by AyBee on Tue Sep 08, 2020 12:04 pm
Needs carbon saddle rails
Just bought one of these (same colour) - can't wait to get it on the road!
omikronphi
by omikronphi on Tue Sep 08, 2020 12:09 pm
Greg0rE wrote: ↑Fri Sep 04, 2020 2:09 pm
Does anyone have any experience with filing the transition spacer for 6degree stem down to make it work with the 12degree stem? Spend ages waiting for the headset kit (S182500011) to arrive only to realise Specialized screwed me on needing yet another special part as it's seemingly not included in the set.
I also had to file down the transition spacer, see my post from a few pages back:
omikronphi wrote: ↑Tue Jun 02, 2020 12:01 pm
Thanks! There's a specific transition spacer available but I forgot to order it.
I had to file down the beading where the cables enter and the parts beside it.
Otherwise the cables get squashed and the spacers will be bent downward against the top of the steerer tube.
Here a new pic in front of a beautifully aged barn door
omikronphi on Wed Sep 09, 2020 6:57 am, edited 2 times in total.
ds240
by ds240 on Tue Sep 08, 2020 1:48 pm
ds240 wrote: ↑Wed Sep 02, 2020 7:20 pm
Has anyone here put a direct mount rear derailleur hanger on their Venge?
If so, any issues and which are you using? I only seem to be able to find one by wheels manufacturing.
Anyone else?
I've ordered the wheels manufacturing one.
