S-Works Venge 2019
bruno2000
by bruno2000
kame wrote:
Tue Jun 23, 2020 10:44 am
I'm finishing building up a 2019 Venge frameset (Bora colors) that I bought recently. I'm reusing a Rotor 3D+ crank with a Power2Max power meter and 54/42 Q-rings from my previous bike (I live in flat country).
I have run into a clearance issue: the front derailleur can't be moved high enough to clear the 54T oval chainring. What are my options? I have read about braze-on adapters but I've never used one - they don't seem like a solid solution. Go back to traditional 53/39 round rings?
(edit: spelling)
Rotor offers some kind of shim for this I think.
anykarthik
by anykarthik
Does this seem like a bad BB on my 2019 Venge Pro? Bike has about 6000 miles on it.
https://photos.app.goo.gl/nmkL88JVq1ufvR5J8
The BB makes noise when I spin it - this noise reverberates through the frame. It's not a grinding/clicking/creaking sound... just a draggy/whooshy sound. Forgive the ambient noise. I will try get a better video later.
Has anyone replaced the stock Praxis BB30 BB with something else? I'd go for a one-piece if I decide to address this.
Visus
by Visus
anykarthik wrote:
Thu Jun 25, 2020 1:33 am
If it makes grinding noises it needs at least servicing. Anyway the resistance is a bit too high but could be a too high preload
ddman
by ddman
Who has the Venge Pro in back matte satin (di2) with holographic decals?
How is the paint and decals holding up after 1-2 years of use?
Thanks
anykarthik
by anykarthik
ddman wrote:
Thu Jun 25, 2020 11:29 pm
Thanks
Haha. the discussion right above your post about a noisy BB is from my matte black with holographic decals that I've owned since September 2018. About 6k miles.
Paint is great. Couple of small scratches here and there. It is harder to clean than a glossy finish though. And tubeless sealant is a pain to get off it.
anykarthik
by anykarthik
icantaffordcycling wrote:
Thu Jun 25, 2020 2:51 am
Looks/sounds fine to me
This video has less ambient noise -- https://photos.app.goo.gl/HHtDeaJCvtcvJbNe8
I reset the preload before taking this video. I also pulled the crank and felt the bearings. They feel smooth. However, I think the drive-side one is the one that is a little noisy. Maybe dry?
ddman
by ddman
tommyb wrote:
Tue Feb 19, 2019 4:50 pm
Sure, mainly the flat top section, prefer the feel of round bars, secondly they're heavier, lastly I can't fit tri-bars.
What bars are you using?
tommsup
by tommsup
(edit: spelling)
You should be fine using a front derailleur adapter. I have tried the Osymetric front derailleur adapter on a Venge together with a Praxis 56/42t combo without issues. https://www.bike24.com/p271907.html
kame
by kame
tommsup wrote:
Sat Jun 27, 2020 8:18 am
(edit: spelling)
Yes, I did just that. Ordered the Osymmetric adapter, installed it and went for a long ride today. It seems to do the trick. Shifts OK and the derailleur doesn't interfere with the chain when not shifting.
In meiner Kette fehlt kein Glied, wenn die Lust von hinten zieht.
nathanong87
Resident master of GIF
by nathanong87
anyone know the size of the upper bearing? is it 1 1/8?
ryanw
by ryanw
Same as the lower...
Allez Sprint Disc - 7.60kg
SL7 S-Works - 6.73kg
www.rhinosworkshop.co.uk
IG: RhinosWorkshop
nathanong87
by nathanong87
ryanw wrote:
Tue Jun 30, 2020 9:50 pm
i dont own a venge and when i look up that part number online, it doesn't say.
but i assume you are implying it's 1.5 upper and lower?
ryanw
by ryanw
OD 49.5
ID 40.5
D 6.5
45/45
Read the additional info: https://www.airevelobearings.com/produc ... t-bearing/
IG: RhinosWorkshop
Bigmac
by Bigmac
nathanong87 wrote:
Wed Jul 01, 2020 12:36 pm
The 2018 onwards bearings are the same as one of the ones used on the Vias - can't remember which!
As RyanW says, follow his link to Airevelobearings, these are correct and the ones you need. The guys at
this company are very helpful and will sort you out
